Check Eng. Light Code:401/402 -96 Explore
Old Jul 15, 2003 | 09:08 PM
digitech's Avatar
digitech
I have problem with my 96 explore check eng. light
I pulled the codes: 401 and 402...replaced the EGR value and still have the check Eng. Light on.
Someone told me its the DPFE sensor.
What is a DPFE Sensor and where is it located?
Thanks..
Old Jul 16, 2003 | 07:28 AM
Rockledge's Avatar
Rockledge
Hello, and welcome to FTE!
It very well could be a bad DPFE causing the codes. Here are a few threads on the subject of the DPFE:
Ford DPFE/EGR System (PDF)
Replacing the DPFE
Old Jul 20, 2003 | 10:39 PM
digitech's Avatar
digitech
Rockledge
Thank you very much.
Just what i needed.
I am glad i found this website
Digitech Guy
Old Jul 25, 2003 | 06:27 PM
SpeedracerGF's Avatar
SpeedracerGF
I know the dealer wants $129 for one, I took mine off and cleaned out the carbon slugde so that the piston operates now. Mine had frozen up, runs like a dream now. (97Explorer)
Old Jul 25, 2003 | 06:42 PM
CobraXP's Avatar
CobraXP
I take it you are referring to the 4.0. The 96 5.0 does not have a DPFE sensor - it has an internal EGR on the intake elbow. Didn't want you looking for it if you have the 5.0...
Old Jul 25, 2003 | 06:47 PM
SpeedracerGF
`97 Expo 5.0 ! (right, maybe I`am wrong)
Old Jul 25, 2003 | 07:03 PM
CobraXP's Avatar
CobraXP
I meant digitech's Explorer...
The 96 and early 97 5.0's don't have the DPFE...
Old Oct 11, 2003 | 01:49 PM
Digitechsys's Avatar
Digitechsys
Re: Check Eng. Light Code:401/402 -96 Explore
What part do i need?
I was told to get the sensor that mounts on top of the EGR Vale.
Part number Motorcraft #F2ZZ-9G428-B
Old Oct 12, 2003 | 06:02 PM
Digitechsys
CAN ANYONE HELP.
I NEED TO FIND OUT WHAT PART I NEED. THE PART I BOUGHT MOUNTS TO THE BACK OF THE EGR VALUE.
I AM NEW TO THIS SO BARE WITH ME.
THE Part number (Motorcraft #F2ZZ-9G428-B)
WILL THIS SENSOR TURN THE CHECK ENGINE LITE OFF?
Old Oct 13, 2003 | 05:57 PM
CobraXP's Avatar
CobraXP
Originally posted by Digitechsys
CAN ANYONE HELP.
Digitecsys,
Welcome to FTE! Please do not post in all caps - it makes it hard to read sometimes. I am not familiar with that part number. What sensor is it, and what code have you gotten from the CEL?
Old Oct 13, 2003 | 06:10 PM
Digitechsys
CobraXP
I am getting the code 401/402 code.
I dont know what the name of the sensor is. But it mounts to the back of the EGR Value which has three bolts. My car is a 96 Explore V8.
Old Oct 13, 2003 | 06:14 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
CAN ANYONE HELP.
if its a 96 or newer model you will have to have a scanner to turn the engine light off, and disconnecting the battery will not do it either.
Old Oct 13, 2003 | 06:18 PM
Digitechsys
I have removed the codes and tried what you have explianed but it came back on.
Thanks for the responce.
Any thing else i can try.
Old Oct 15, 2003 | 07:00 PM
Duthlerfordparts's Avatar
Duthlerfordparts
F2ZZ-9G428-B is an EGR position sensor if I am not mistaken.
Old Oct 15, 2003 | 08:18 PM
Digitechsys
Thanks
Will this take care of the Check Eng, Light.
If you have any suggestions please let me know.
Again thanks for the response.
Digitechsys
