i just got a 1996 f450 wrecker 7.3 diesel. well problem is when i try to start up the truck is having hard start. it takes 2-3 times trying to start for it to run. after runs rough for a couple moments then acts fine any ideas
That really doesnt tell me anything other than the glow plugs are new. I hope they are beru or motor craft. ANYTHING else is just looking fro problems.
but there are several other pieces involved with the glow plug stytem.....
-The Ecm which tell the system when to turn on and grounds the solenoid to turn then on
-The wire come from Ecm to relay
-The relay
-The constant 12v power wire
-the keyed 12v power wire
- The wires running from solenoid to the valve cover harness'
-the plugs
-the Valve coverGaskets'
-last but not least the Under Valve Cover Harness'
