Anyone have a complete 69 F100 wiring diagram, showing both the cargo light and interior parking brake light wiring? I have a diagram and those are the only things missing.
Also, I seem to be missing the switches for both!
Thanks!
Thanks!
Thanks!
Just a heads up on the brake warning light that goes to the 20 amp main fuse.
If for some reason the light or wire shorts out the 20 fuse will not blow out.
But your whole wiring harness under dash will melt where it wire wraps around will burn the insulation off.
Put a fuse between the main and the warning bulb inline with like a 3 amp fuse.
I learned the hard way.
Orich
