69 F100 Wiring Diagram
Anyone have a complete 69 F100 wiring diagram, showing both the cargo light and interior parking brake light wiring? I have a diagram and those are the only things missing.
Also, I seem to be missing the switches for both! Thanks! |
Here you go:
Originally Posted by doug51f1
(Post 14731284)
Thanks!
As always, you guys never cease to amaze me! Thanks so much!!!:-drink
(Post 14731284)
Also, I seem to be missing the switches for both! Thanks! If for some reason the light or wire shorts out the 20 fuse will not blow out. But your whole wiring harness under dash will melt where it wire wraps around will burn the insulation off. Put a fuse between the main and the warning bulb inline with like a 3 amp fuse. I learned the hard way. Orich |
THANK YOU!!!!
