codes...
Old Jul 15, 2003 | 06:06 PM
bds's Avatar
bds
Question codes...
I've done several searches for build codes on these forums and about all I get are answers to specific questions from other owners, a method for obtaining an already-decoded build sheet for my vehicle and a few links to vin decoder sites.
I've got an '86 F350 Crew Cab 4x4. I bought it from the second owner, who passed on to me the original build sheet! (The original purchaser laminated it.) Where can I go to find out how to decode it without requesting another one? I don't even think I could because my door sticker is gone.
Thanks in advance,
Blake
blakesims(No Email Addresses In Posts!)
Old Jul 17, 2003 | 10:26 PM
steve83's Avatar
steve83
codes...
If you have the build sheet, what needs to be decoded? Can you scan it & put it up on the web somewhere? Possibly at SuperFord's Registry like my signature?
Old Jul 18, 2003 | 10:16 AM
bds's Avatar
bds
codes...
steve83,
Sorry, maybe what I have isn't actually the "build sheet" after all. I don't have access to a flatbed, but I'll try to email you a low-res digital pic of the form. What I've got is a form with sections labeled A through M, one line at a time. On A for instance, are the subcategories: rotation number, VIN Position, truck line, body, type of cab, Paint (with sub-subcategories body, accent and tutone deluxe), Trim (sub-subs A-26, scheme, color and seat), A-30, Floor mats or carpet, deluxe belts, console, headliner, remarks, region, district and special order (where there are choices DSO PSO and PTO).
That is just line A of A through M. Not every category has an entry, but the ones that do are letters or numbers. For example, On line G the second and third position are for the rear axle. It says C9, so I've been able to look that one up because it's pretty common, but I've got no idea about 99% of the rest of it.
Any help would be great!
Thanks again,
Blake
Old Jul 19, 2003 | 12:47 AM
steve83's Avatar
steve83
codes...
Sounds a lot like the info on the door sticker. Have you dl'ed this PDF from the Ford site? It lists a lot of the codes that were used in the mid-80s. If you want to see a similar list of '83 codes, e-mail me & I'll attach a few interesting VIN documents. (That offer is open to anyone - just be sure to specify what you want, and mention FTE so I know what BBS you use.)
