Sponsored by: Real Truck
2003 6.0 random idle shake
Old Oct 8, 2014 | 07:36 AM
evan1242's Avatar
evan1242
Hey guys, i recently bought an 03 F-250 6.0 Lariat crew cab FX4.
it has an EGR delete, ARP studs, and the updated oil cooler.
it has 138,xxx on the clock.
randomly, only when it is at normal operating temperature it will have a slight shake to it at idle. when i try to take off from this shaky idle it feels like it is "missing" i guess you could say. it clears up about 1/8 a mile down the road everytime. And i will go ahead and say this does not happen everytime it idles. Only maybe once or twice in a 30 minute trip.
Do you guys have any idea what might be going on?
i have not added a coolant filter yet, and it does not have synthetic oil in yet either (just bought it) i plan to use full synthetic Rotella 5w40 very soon.
i think this might be a stiction problem? but i read it is uncommon to have stiction when warmed up.
i do not have anything yet to pull codes or read the FICM yet. both batteries are good.
Thanks for the help in advance! this site has provided so much info already!
Old Oct 8, 2014 | 07:58 AM
MC5C's Avatar
MC5C
Check the FICM and install the fuel pressure regulator spring update (blue spring update). Low fuel pressure is the most common cause of misfiring and bad injectors.
Old Oct 8, 2014 | 08:19 AM
evan1242's Avatar
evan1242
yes, i forgot about the blue spring upgrade. do i order that kit from ford?
i also just did OEM fuel filters as well.
Old Oct 8, 2014 | 11:49 AM
evan1242's Avatar
evan1242
i forgot to add, that it is more likely to happen after a period of WOT.
going to change oil to full synthetic rotella 5w40 tomorrow.
Old Oct 8, 2014 | 11:57 AM
MC5C's Avatar
MC5C
You can get the kit from any ford dealer or on line. Having the bad idle happen after WOT indeed points to the fuel pressure as a problem, fuel pressure will be lowest at WOT. It's possible that you've damaged your injectors if that is the case, and at the least I would drive it very easy until you get the upgrade kit installed.
Brian
Old Oct 8, 2014 | 12:19 PM
evan1242's Avatar
evan1242
Brian
sounds good. going to call ford now. maybe just maybe they will have one in stock
Old Oct 8, 2014 | 12:23 PM
evan1242's Avatar
evan1242
ok i will have the kit tomorrow. i really hope the injectors are ok. i can't afford those right now!!
92mnfordtrk
Nov 14, 2017 01:47 PM
evan1242
Oct 20, 2014 03:58 AM
power stumped
Sep 14, 2014 03:41 PM
DieselVol
Aug 27, 2012 10:32 AM
iqzero
Mar 11, 2009 09:32 PM
