explorer stereo/trim removal question
Old Jul 15, 2003 | 04:52 PM
chuck641's Avatar
chuck641
can someone tell me how to pull the trim off the dash of a 2002 explorer. i need to pull the stereo out and im pretty sure the trim all pops off but i didnt want to pull too hard and break it.
thanks, Jason
Old Jul 15, 2003 | 08:07 PM
chamill's Avatar
chamill
Jason,
I've got a 2003, but I believe they are the same. To get the trim off I took a relatively wide paint scraper and put it between the trim and the plastic on the right hand side of the radio. With a little bit of pressure you should be able to loosen the clamps right up and have them let go.
It took a little more pressure than I would have thought, so don't be afraid, give it a good yank. Also, don't use a screw driver as it is too narrow and can damage the plastic.
good luck.
Old Jul 16, 2003 | 09:25 AM
PrPlayboy's Avatar
PrPlayboy
I have better luck going from the bottom. I can remore the trim panel even that way. It does take a bit of pressure to remove.
Old Jul 16, 2003 | 12:24 PM
chuck641's Avatar
chuck641
thanks, i figured it popped off but since its not my car i didnt want to bust it.
-Jason
Old Jul 16, 2003 | 01:05 PM
Soulseeka's Avatar
Soulseeka
Don't know a lot about '02's but look carefully for hidden screws.
