excursion brakes suck
Old Oct 8, 2014 | 12:15 PM
Excurvelle's Avatar
Excurvelle
As a fellow Ex owner I beg you to please have trailer brakes, 6000 lbs is still heavy and will push you when coming to a stop.
Old Oct 8, 2014 | 02:36 PM
nojoke327's Avatar
nojoke327
I'll be doing my x/b codes soon so when I'm in there I will inspect everything and lube the pins.
Old Oct 8, 2014 | 04:09 PM
hav24wheel's Avatar
hav24wheel
Originally Posted by Krazee Matt
Yeah, I didn't enjoy that day and neither did my wallet. Nor did yours. OP, I'm with the others that have suggested a full bleed to get new fluid everywhere. I'd also consider replacing the soft lines with the Russell (696490) braided set as the soft lines can deteriorate over time internally, causing more issues.
I had that happen too, I fixed the calliper, and left the rotor on there. Took a little wile for the new pads to take the shape of the rotor, but no problems here.
Old Oct 8, 2014 | 06:35 PM
Paul Titus's Avatar
Paul Titus
Did they switch out the rear small discs for anything larger after '03?
When I did my brake job I noticed how small those rear discs were and I was curious as to why they went so small. I would think upgrading those to larger rotors and rebalancing the system would provide better braking for those towing larger trailers.
Old Oct 8, 2014 | 06:43 PM
nojoke327's Avatar
nojoke327
Ford went bigger in 05 and again in 13. I've read that brakes can be converted but I don't know what's involved
TheLex
Apr 28, 2018 06:45 PM
actech
Jun 26, 2013 09:47 AM
ford&excavators
Nov 25, 2007 11:17 AM
rfont54
1997 - 2003 F150
Jan 3, 2007 08:18 AM
kneeknocker63
All Things Towing
Sep 8, 2005 08:32 PM
