2012 f250
Old Oct 7, 2014 | 04:08 PM
yendor0801's Avatar
yendor0801
2012 f250
Hello, I have a 2012 F250 with 21,000 miles. Over the last 6 months, I have had 5 or 6 instances where Im driving and barely on the accelerator and the engine or transmission shakes or vibrates violently. Its happened at around 40mph and 70mph. It seems like the engine is not getting the right amount of fuel or maybe its the transmission stumble or shake that I have heard about. It is a fast back and forth of either the engine knocking or gasping or its the transmission. It can be very bad.
I went to the dealer and of course, there were no thrown codes on the pcm. They did the reflash and 20+ miles of driving and said there is nothing wrong.
Last night, I was on a country road at about 40 mph and it happened again. If I press the accelerator down harder, I will stop. If I keep the accelerator at the same spot, it seems like it would just knock, or shake violently forever.
Do we think this is an engine issue or a transmission issue? Anyone had something similar.
ITs not a slow back and forth of the transmission like Ive seen in older cars. IF it is the tranny, its happening really fast..if not, its maybe the engine?
I cannot tell or dont have enough knowledge to know if its an engine prob or transmission. I just know it sounds and feels like the world is ending and the shake, knock and vibration is going to tear the truck up..
PLEASE HELP!!!!! I DO HAVE IT ON VIDEO I JUST DONT KNOW HOW TO POST IT.
Old Oct 7, 2014 | 04:25 PM
Chad149's Avatar
Chad149
Is the truck in the middle of an active regen? There was a bulletin for something along the lines of what you describe if occurring during regen.
Old Oct 7, 2014 | 07:35 PM
Lastwagen's Avatar
Lastwagen
My 2012 did it at the start of an active regen. The dealer couldn't identify the problem. There's a TSB for the fix. Left bank valve job.
Old Oct 7, 2014 | 08:58 PM
elee3's Avatar
elee3
Lastwagon, did you have the work performed? If so, how did it go? I have experienced this problem at the beginning of active regents before but now it happens very rarely and I'm not sure I want them tearing into my engine. My last truck had head gaskets replaced by Ford before I bought it, and they tore up all kind of stuff in the process. Little things like clips and mounting brackets and bigger things like rung off valve cover bolts. I have gotten to where there's nobody that I trust to do a quality job.
Old Oct 7, 2014 | 09:21 PM
pstroke67's Avatar
pstroke67
Here's the tsb
*Printable View (1170 KB)
TSB
13-9-15
6.7L DIESEL ENGINE - RUNS ROUGH/MISFIRE DURING EXHAUST REGENERATION PROCESS
Publication Date: September 13, 2013
FORD:
2011-2013 F-Super Duty
The article supersedes TSB*13-5-17*to update the Service Labor Time Standards and Part List.
ISSUE:
Some 2011-2013 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit a runs rough/misfire condition only during the exhaust regeneration process. This condition typically occurs on light throttle tip in between 64-113 Km/h (40-70 MPH), and will not set diagnostic trouble codes (DTCs). The concern may be intermittent and a knocking noise may be present during the concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Did the customer indicate the message center displayed a Cleaning Exhaust Filter message prior to the concern?Yes - proceed to Step 2.No - this article does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.Using Integrated Diagnostic System (IDS) or equivalent, retrieve DTCs from the Powertrain Control Module. Are DTC's present?Yes - this article does not apply. Refer to the PC/ED manual for normal diagnosis.No - proceed to Step 3.Remove the left hand cylinder head. Refer to Workshop Manual (WSM), Section 303-01.Replace all eight (8) exhaust valves and valve seals. Refer to WSM, Section 303-01. (Figure 1)*
Old Oct 8, 2014 | 06:43 AM
Lastwagen's Avatar
Lastwagen
I learned about the TSB (previous post) after I had taken it to the dealer. Strangely the problem subsided for months and I thought maybe mine was a different issue that went away. It came back with a vengeance however and was worse than before. By then I was nearing the 3yr/36k mark so I went to the same dealer and suggested I might consider a trade on a 2015 rather than deal with the major repair. They allowed me a good trade-in and now the truck is theirs. Since it was warranty it was no loss to them. Everybody's happy.
Old Oct 8, 2014 | 10:45 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by yendor0801
Hello, I have a 2012 F250 with 21,000 miles. Over the last 6 months, I have had 5 or 6 instances where Im driving and barely on the accelerator and the engine or transmission shakes or vibrates violently...
Hi yendor0801,
I want to get this into the hands of your regional customer service manager. All I'll need to make that happen is a PM from you with your full name, best daytime phone number, VIN, current mileage, and servicing dealership.
Crystal
Old Oct 8, 2014 | 03:39 PM
yendor0801's Avatar
yendor0801
PM
RODNEY 1234567889
Last edited by yendor0801; Oct 14, 2014 at 12:56 PM. Reason: getting rid of personal info
Old Oct 14, 2014 | 10:50 AM
yendor0801's Avatar
yendor0801
CRYSTAL I HAVE NEVER HEARD BACK FROM YOU OR FORD
Old Oct 14, 2014 | 10:53 AM
SavageNFS's Avatar
SavageNFS
send her a private message, not post your information here.
Old Oct 14, 2014 | 11:51 AM
my_crib_too's Avatar
my_crib_too
Looks like you could give her a call too, judging from Crystal's signature.
bruce...
Old Oct 14, 2014 | 12:51 PM
FordService
Official Ford Rep
Hi yendor0801,
I recommend editing your public post to remove your private information. Send me a private message (PM) with that information and I'll be happy to assist. If you prefer, you can contact our Customer Relationship Center at 1-800-392-3673; they can offer the same assistance that I can.
Crystal
Old Oct 23, 2014 | 01:02 PM
yendor0801's Avatar
yendor0801
my question is how can we spend this much on a truck and have so many problems
Old Oct 23, 2014 | 04:20 PM
Unrealo4's Avatar
Unrealo4
You obviously have not visited the 6.0 forum!
Old Oct 30, 2014 | 10:25 AM
yendor0801's Avatar
yendor0801
i have not visited the 6.0 forum, but I think would be scared too....
At this point Ford is doing:
only valves and the new program.
hopefully this fixes the problem
