2000 E250 5.4L Climate control system
Old Oct 6, 2014 | 05:23 PM
Ooghammer's Avatar
Ooghammer
Mine has 130K , has sat for nearly two years . Put a battery in it and changed oil . Started it up . Wouldn't idle from sticky idle stepper motor but freed that up with carb cleaner . Idles beautifully and ran it down the street a few times and so far so good . No codes .
The one issue is no matter what selection I have the air on except for off , is the air comes from the defroster vents at what seems to be "normal" flow (as opposed to max) . I don't thing the air compressor is cycling because the idle didn't change . I'm thinking something is sticking but if someone can help with troubleshooting I'd greatly appreciate it .
Old Oct 7, 2014 | 05:07 AM
Wildman25's Avatar
Wildman25
Most times when the air blower goes to only the defrost vent, you have a vacuum leak at the heater/AC controller. Default setting.
Check under the hood (right side) on top of the heater/AC box, you'll see a wire connector, and a small vacuum line, check that line for vacuum. Also, there is a vacuum line that runs behind the box, and down to the back side of the heater box, check that line for vacuum.
Although the heat/air switches on the dash are electrically controlled, they in-turn control servo motors that are "powered" by vacuum, to open/close directional "doors" inside the heater box.
Check your vacuum lines up front first, if you have no vacuum present, the lines run along side the right side of the engine, and over to the upper intake plenum.
The '92 I'm driving now, didn't have much use on it, the heater was not working, and I pulled the blower motor off for replacement, and found a large mouse nest inside the heater box
Shop vac the nest out, new blower motor and resistor, and the heat was working fine.
If your van was sitting as you said, pull the blower motor for above ^ story.
Also the engine was idling high, and I replaced every vacuum line on it, 20 year old rubber gets bridle and cracks, and leaks, and that solved that problem. Something you might want to check also. 6 feet of 5/32" vacuum line goes a long ways.
If the AC compressor is not cycling, that's a sign that the system is low on freon, or a leak in the system. You can check this with getting a can of R134 with a gauge on the can, and fill tube, and on the far right side, on the air dryer canister, is the LOW test/fill port, follow the directions on the can, and that should give you an idea of what you have.
Old Oct 7, 2014 | 09:04 AM
Ooghammer's Avatar
Ooghammer
Ok , will check for those items . Thanks for the reply .
tagnamee
Aerostar
20
Aug 14, 2020 09:33 AM
dino360
Jul 3, 2018 09:09 AM
Ninra
Sep 30, 2013 11:53 AM
minnesotafisherman
Oct 17, 2012 11:08 PM
saanders
1978 - 1996 Big Bronco
Aug 18, 2003 07:14 AM
