Have a stock 460 that is going to have the heads pulled off soon. To put new valves and springs... was wondering what kind of gains could I get swapping the cam as well leaving everything else stock. 88 7.5. Talking to a first timer so don't be over technical please.
The real HP improvements are in the cylinder heads. But you will gain some HP with a cam change but don't expect miracles.
While most folks buy cams from the guys who advertising budget is huge I prefer to deal with smaller cam outfits who can grind a custom made grind for your application. Better cores… personal service.
EFI 460s did not have the timing chain set to 4-8 retarded, they were straight up. +2 on the custom cam recommendation if you do not have the coin for reworked heads.
