6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
engine shuts off while running
Old Oct 6, 2014 | 11:55 AM
JBnpa18074's Avatar
JBnpa18074
I have a 2008 f350 crew cab 4 wheel drive 6.4 diesel and it has about 147 000 miles on it . it has recently been shutting off under power and at idel . I notice the the clustor on the dash reading so many miles to e . The miles go up and down sometimes it drops 4 miles in a matter of min. it the comes back. The dealler had it for 3 days and could not get it to shut off . I just got it back and it sarted doing it again. Was wondering if anyone else is having this problem?
Old Oct 6, 2014 | 05:57 PM
senix's Avatar
senix
I take it no check engine light?
Does it start back up right away?
do you have a wrench symbol?
Old Oct 7, 2014 | 06:26 AM
JBnpa18074's Avatar
JBnpa18074
No check eng light , it will start right up after . Like i say the dash cluster is on the mode where it reads how many miles to E The is going crazy it will tic down as you watch and drop 20 mins in 5 sec
Old Oct 7, 2014 | 06:27 AM
JBnpa18074's Avatar
JBnpa18074
it does not show anything on the dash to clue as to anything
Old Oct 7, 2014 | 07:21 AM
senix's Avatar
senix
This sounds to me like a wiring harness issue.
Check the wiring harness connections at the firewall by the airfilter. Check for pushed or bent pins.
Old Oct 7, 2014 | 10:01 AM
a4t1rat's Avatar
a4t1rat
Now this brings back memories.... I second the wiring issue. Start it up and start wiggling all the connections you can find.
Old Oct 7, 2014 | 02:04 PM
JBnpa18074's Avatar
JBnpa18074
Yea i am thinkinf computer or wiring . It also flutters some time like it was running out of fuel. But with the elec display acting up i am agreeing something electrical. But that gives me a place to start. Thanks
Old Oct 13, 2014 | 10:21 AM
JBnpa18074's Avatar
JBnpa18074
code readers
hi what is the best and cheapest way to get a code reader to see what the computer is putting up as codes ?
Old Oct 14, 2014 | 06:29 AM
muntu's Avatar
muntu
have read that napa and autozone will read for free....I use the edge insight plugged in perm.
how long have you owned the truck...how many miles have you put on?
is the screen monitor stuck on miles to Empty? if you keep pushing the button does the screen cycle to other pages?
is the truck tuned?
still have a dpf?
Old Oct 14, 2014 | 09:53 AM
JBnpa18074's Avatar
JBnpa18074
have 147000 plus on truck have owne it new since 08 still all factory The codes that are coming up are 2( p0528,p0480) for cooling fan one for brake switch and one for no injection pressure p2291 and p2291
I notice my anti freeze empties out or boils off . Trying to keep an eye on it and see if it cuts off when the anti freez burns oof.
Old Oct 14, 2014 | 11:30 AM
senix's Avatar
senix
0480 Fan 1 circuit
0528 circuit no signal
2291 could be a fup sensor, batter voltage..who knows.
I would replace/check the wiring for the fan circuit, clear the codes and see what you get.
derek0525
Oct 28, 2010 08:50 AM
oldfisherman
2009 - 2014 F150
Jul 10, 2010 05:17 AM
EK33
2004 - 2008 F150
Oct 14, 2004 05:47 PM
medicpg
1983 - 2012 Ranger & B-Series
Apr 29, 2003 03:18 PM
