Starting my build
Old Oct 5, 2014 | 11:41 PM
logger1989's Avatar
logger1989
Starting my build
Here's my situation. I currently own a 1989 7.3 with a banks kit, 4" exhaust, cranked stock pump, home made cai and a few other things. The way it sits it will pull pretty hard on a stock 7.3, and I've already pissed a few cummins guys off, but I still want more.I have began to accumulate parts. And will start when I have more time this winter. Here is what I'm throwing into the mix:
Dps head studs (already have)
2001 super duty intercooler (already have)
Fass lift pump (already have)
R&d 110cc ip
R&d stage 1 camshaft
Here's my question, when will my turbo become a limiting factor? Any guesses on what hp I could expect from this build? I'm guessing I'm 230 ish the way I am right now. Any other suggestions?
Old Oct 6, 2014 | 01:10 AM
Ford F834's Avatar
Ford F834
Your turbo will definitely be the limiting factor with the 110cc if it isn't already with the turned up 7.3L pump. Depending on the efficiency of your turbo, exhaust, and driveline loss you can expect to see anywhere from 2.3 to 2.7 hp at the wheels for each cc of fuel delivered. With an efficient turbo you should be very close to 300 hp at the wheels. Looking at your list that is the one component that is inadequate compared to everything else. I am starting a very similar build to yours, and went with a Borg Warner S360 hybrid .85 A/R T3 S200 frame hot side. I am pretty excited to see how that combination works out. But yeah. You are definitely going to want a better turbo.
Old Oct 6, 2014 | 01:32 AM
logger1989's Avatar
logger1989
Any thoughts about going with a cab controlled vgt? It would provide all the air I would ever need and I have one laying around haha
Old Oct 6, 2014 | 01:46 AM
Ford F834's Avatar
Ford F834
dirtydiesel is the guy who has played around with that... Using a few different control methods.... Have a read...
https://www.ford-trucks.com/forums/1...1ve-turbo.html
Old Oct 6, 2014 | 01:47 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Ive looked into a vgt as well, without a controller it would be a pita to drive imo. Will be interesting to see what that turbo will do, anderson thinks it still has some more in it with a 90cc. My revised build is much the same as yours, except for a better IC slightly lower compression (was already milled .015" when it was rebuilt" R&D pipes and something like a S360.
Old Oct 6, 2014 | 01:57 AM
logger1989's Avatar
logger1989
Hmmm the one I have is from a 6leaker. I doubt I'll take that road just throwing it around haha. What about a stock 7.3psd turbo with a few upgrades? I don't know a ton about turbos but I know I'll need to learn for this build
Old Oct 6, 2014 | 11:53 AM
hairyboxnoogle
You would be way money ahead to just buy a turbo rather than trying to make one work from a 7.3 PSD. You can get a BW box turbo for like $600 brand new.
Would be really neat to use one, If you could control it even with springs or a wastgate, i would try it.
Old Oct 6, 2014 | 01:50 PM
logger1989's Avatar
logger1989
Okay I'm thinking along the lines of a bw s400. I can handle the exhaust side of things, however never doing any turbo swapping, how would I adapt the oil system?
Old Oct 6, 2014 | 03:36 PM
Arps 6.9's Avatar
Arps 6.9
Why go with a s400 series instead of a 300 series turbo?
Old Oct 6, 2014 | 05:25 PM
hairyboxnoogle
400 is way too big a 366 is already too big. Unless youre running 200+cc of fuel and turning 4500 and only looking for top end, a 400 will be all but useless. A 366 would work decent with your stock turbo in a compound setup however. if you are looking at BW, a S360 or S362 are going to be close to ideal.
Old Oct 6, 2014 | 09:41 PM
Arps 6.9's Avatar
Arps 6.9
A 66mm will be alright for 110cc's I think, besides, they are about the most affordable 300 series turbo and I like mine on my 90cc's, but like HBN said, they are much better for the high cc pumps.
Old Oct 7, 2014 | 08:41 PM
logger1989's Avatar
logger1989
A local turbo shop has a seemingly light used s362 for 450. Should I jump on that?
Old Oct 7, 2014 | 09:48 PM
Ford F834's Avatar
Ford F834
That's a pretty good price, but it really depends on the A/R of the hot side. That will make the difference between spooling and not. Also the S300 frame hot side is not T3 iirc, and won't be a bolt on to your banks kit pipes if that was your plan. That's why I dropped the coin to have an S200 hot side with a .85 A/R and a T3 flange machined to fit the S360. I am thinking it will move plenty of air for the 110 plus have decent response. Read through Justin's thread, I believe he was running a 362 for a while...
Old Oct 8, 2014 | 05:17 PM
logger1989's Avatar
logger1989
I was gonna have by buddy help me adapt my up pipe for whatever flange I needed. Other than that what would it take to slap an s300 based turbo in there?
Old Oct 8, 2014 | 05:28 PM
hairyboxnoogle
362 would be a good turbo for 110, might be a little laggy, but will have plenty of top end. Thats what im debating currently... S360, or S362/363. Probably has the .88 or .91 T4 housing but you might get lucky and it has a T3 on it. You would want the .91 T4 housing if possible. An 093 hotside can be machined for the S300, justin has / can get them new, he also has my outlet, which is for sale, but thats up to him, whether he still has it or not and/ or wants to get rid of it. That way you will be wastegated and will bolt to your up-pipe.
