Instrument panel lights
Old Oct 5, 2014 | 08:59 PM
460harris's Avatar
460harris
Got a different instrument panel and the lights are not working. The plug on old one has same amount of wires but is smaller than new one. New one has three wires that r different color than what truck has. Yellow/ black tan/black and red. The rest if wires were same color as truck.
Old Oct 5, 2014 | 09:22 PM
Jklnhyd's Avatar
Jklnhyd
Are the instrument clusters identical, if not, they are not swappable.
Old Oct 5, 2014 | 09:35 PM
460harris's Avatar
460harris
No one the one from the truck was just warning lights. The new one is gauges and lights. The gauges work the blinker lights work. The seatbelt light works but. The illumination lights do nori had to swap plugs out.
Old Oct 5, 2014 | 11:34 PM
51M1's Avatar
51M1
I just did a full instrument cluster swap in my 72 F100. I had to change the wiring harness to make it work. Found a good used one reasonable on Ebay.
Try taking out the bulbs, clean the circuit board where the lights
go with an eraser and try swapping the bulbs from your old cluster. Also check your fuses.
I just read that the gauges work so probably your harness is ok.
Check both gauge clusters and make sure the light traces on the circuit boards go to the same pinout on your connector.
Old Oct 6, 2014 | 10:07 AM
460harris's Avatar
460harris
Thanks 51m1. I'll look in ebay and see what I can find on ebay. I'll try the eraser thing also.
Old Oct 6, 2014 | 04:06 PM
51M1's Avatar
51M1
Find where the circuit board lines from the cluster lighting go. Check with a multimeter on the corresponding pins on the harness connector. If they are on the same pins as the cluster and have voltage that varies from 12vdc to 0 when the dimmer switch is turned the harness is ok. It could be your light switch as well. Swapping the harness is a big job. Make sure it has to be replaced first.,It could be something simple. If the gauges and signals work. Your harness is most likely ok.
Ole Green 1978
Jan 23, 2012 09:37 PM
360ranger74
Feb 26, 2004 12:35 AM
wiznewski
Feb 8, 2004 12:56 PM
haviation
Sep 28, 2003 05:51 PM
040498
Jul 17, 2002 02:59 PM
