HELP Rumble strip noise
Old Oct 6, 2014 | 05:01 PM
ExcursionQ13's Avatar
ExcursionQ13
Actually there was no noise?? Meaning....?
Old Oct 6, 2014 | 05:44 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Most likely it put tension and pressure on whatever component is worn and causing the noise when it has a little room to wiggle when in 2wd. Still recommending you pull the bearings, hubs, and visually inspect them. Just because they're relatively new doesn't mean they're still in good shape.
Old Oct 6, 2014 | 07:02 PM
ExcursionQ13
Originally Posted by Krazee Matt
Mine had this exact same issue, both the front wheel bearings were destroyed.
Also pulled the hubs off to inspect them and they too were in serious need of grease. Ended up replacing them too they were so far gone.
When you had this problem did the noise seem to be from the passenger or drivers side? Or couldn't really tell?
Old Oct 6, 2014 | 07:12 PM
Krazee Matt
Veteran: Navy
Couldn't tell, it was hard to pin down because it was so violent and reverberated throughout the cabin. It was bad enough that it FELT like rumble strips as well as sounding like em.
Bearings, just like brake rotors, pads, calipers, tires... should all be replaced in pairs if budget permits. That's why I did both bearings and both hubs.
Old Oct 6, 2014 | 07:18 PM
ExcursionQ13
Same with this. It FEELS like the strips. But after replacing everything on the drivers side, it could possibly be the passenger side bearing/hub...
Personal opinion, do you think best chances are Ujoints or the passenger hub/wheel bearing?
Old Oct 6, 2014 | 08:00 PM
jamesbfishin's Avatar
jamesbfishin
Unless you are locked into 4wd the front ujoint shouldnt be turning, so good chance its not the front axle ujoints. I think one of Matts earlier posts is probably the best guess with a front wheel bearing
Old Oct 6, 2014 | 08:13 PM
ExcursionQ13
Gonna try driving with hubs locked but switched in 2wd so hopefully no noise. If not, will def be checking the passenger side completely! Thanks man
Old Oct 6, 2014 | 08:27 PM
Krazee Matt
Veteran: Navy
Driving in 2wd is just going to mask and hide the issue, you seriously need to tear into the damn thing and find out what the reason is. Razzi (Toreador_Diesel) can attest to that fact. When mine **** the bed I was in the middle of a cross-country road trip towing 45-4700lbs, and I was trying to push as far as possible before repairs. The bearing noise changed pitch completely, seizing a split second later, grenaded the hub and threw me and and the trailer off the highway at 60mph into the Arizona desert. Took out a mileage sign, obliterated the windshield, and damn near rolled both rig and trailer.
Long story short, find out what's wrong and fix your ****. Now.
Driving in 2-wheel with the hubs locked isn't the best thing in the world unless you enjoy spending money and replacing hubs. I'm taking a shot in the dark here and guessing you don't pull them off regulary (every few months) to grease em up and inspect them, which really should be done. 8-15 miles at higher speeds, sure why not. But after that even synthetic high-temp grease isn't going to really enjoy what you're putting them through. Also from experience, which is why I now have Warn's on mine instead of the ESOF stocker's.
Old Oct 7, 2014 | 07:46 PM
The2003Excursion's Avatar
The2003Excursion
Have you checked the Track bar? I have seen You Tube videos of that and they really shake things up.
Old Oct 8, 2014 | 07:21 AM
Krazee Matt
Veteran: Navy
Trackbar can cause some serious death wobble, but nothing like this. It's wheel bearing or hub related.
Old Oct 8, 2014 | 03:00 PM
ciscofreak's Avatar
ciscofreak
Following this thread as my 02 Excursion is doing the exact same thing...
Old Oct 8, 2014 | 08:36 PM
Joe Knockwafel's Avatar
Joe Knockwafel
Hello. I had a SD f350 in the shop for the same complant. If you lock the front hubs in, and put it in 2wd and the noise ,and virbation stops. The problem is the small niddle bearings ,on the inside of the hub bearing, at the axle ,snout side. The bearing ,and axle are gaulding up. With the hubs unlocked ,the wheel hub is spinning, butt the axle is not. When you hit a bump the axle jumps around and grabs the bad bearing.Pull the hub assembly off and look at the inside bearing ,and axle. Joe
Old Oct 8, 2014 | 10:50 PM
  #28
Apocalypse's Avatar
Apocalypse
So you're just saying it needs new needle bearings? Seems like it's a bigger issue than that... just saying.
Old Oct 8, 2014 | 11:47 PM
  #29
Krazee Matt
Veteran: Navy
They aren't rebuildable, serviceable units. If one component is toast, it's a full replacement unfortunately.
Old Oct 9, 2014 | 06:09 AM
  #30
Joe Knockwafel
Needle bearing part # Ford c6TZ-3123A Napa, Rock auto B2110 I would normaly replace the whole unit. Butt the needle bearing can be just replaced. Joe
