I'm kinda back
I'm kinda back
It's been a long time and I kinda missed this forum 'cuz it's got a lot of great folks on it.So,why did I leave? It's called upgrading to a 40' diesel pusher with a Cat 330 turbo and managing to sell the '01 PSD"Ex" and the '05 Cougar 304 BHS travel trailer as a package and making $5K on the deal.
I MISS MY "Ex" and I have a POS '11 Jeep Liberty as a toad and daily driver.
Soo, I'm thinking of looking at an '05 PSD for a driver and need to know what I need to look at in one of these. I figger that if I set it up like my '01,A&E intake,DP tuner and 4" exhaust,I can get it up over the MPG of the Liberty. When I sold the "Ex" it was getting 20 freeway,14-15 city and 10.5 towing 9600#. The POS Liberty gets 12-13 mpg city and 18 freeway and doesn't even like to tow my utility trailer. Oh,and it's built by Dodge.
Welcome back- yeah I know a couple of folks who have bought Libertys based on the Jeep nameplate, but out here in the country there's nothing Jeep about them. They might as well call it a Yugo the way things break and as cheaply built as it is!
Good luck finding an 05- you'll have to deal with the 6.0 issues or buy one that's been 'bulletproofed' (which means get receipts to show what was done!).
Or, find an early '03 with a 7.3 and live happily ever after!
Toreador D has had some recent excellent info regarding what to look for in the 6.0 AND 7.3 vs 6.0 arenas...
Good luck
Good luck
Fiat. New 2015 Jeep Renegade 2.4L nine speed transmission and it looks just like the Fiat 500 four door that my wife's friend drives. Evidently,it's being built in the US By Fiat.
Some excerpts from TD's inputs on another thread, detailing the 6.0. He has both a 7.3 and a 6.0 so he's not a biased nor a bandwagon source.
Might want to grab some coffee, this will be a good read.
The 6.0 is an amazing piece of technology that people are generally afraid of becuase of it's history.
The people who bad mouth the 6.0 fall into a few categories:
-They've owned a 6.0 new and had bad luck with it.
-They bought a 6.0 used and ended up buying someone else's problem
-They've never owned or had any experience with the 6.0, but love talking trash. (Most common category)
When I bought my 2005 Excursion, I bought prepared to sink some money into it if I had to. Come to find out, mine had a clogged oil cooler and leaking EGR cooler which meant some work needed to be done. The sales folks were shocked and appalled when they saw me hooking up the AE. They had no clue what it was, but were even more shocked when they found out how much I knew about the engine and they didn't. The look on their face was priceless....
. I drove it home to Houston 700 miles from Amarillo and promptly dropped it off at Powerstroke Enginuities to have them bulletproof the engine. $3500 later (other shops quoted me WAY more, $5-$6K range), I essentially had a brand new engine as they resealed everything, replaced the headgaskets (didn't really need to, but had the money), installed ARP studs, installed an EGR delete and new Oil cooler, and a few "while the engine is out" things so I didn't have to think or worry about anything. Which to this day I don't, I just turn the key and drive everywhere with this grin on my face ->
The long and short of it: Did I really have to go that far to make my 6.0 reliable? No I didn't. I could've simply had PSE replace the oil cooler and EGR cooler and kept driving the truck. Even then, had the truck been perfectly healthy, I would not have had the engine work done and just driven the truck stock. At most, I would've flushed fluids, changed filters, and called it a day. The 6.0 is nothing to be afraid of. It will run circles around a stock 7.3 any day. (This is coming from a 7.3 owner since new 401K on it now) Between the air management system, the VGT turbo, 4 valves per cylinder (vs 2 on a 7.3), the bulletproof transmission (from the factory btw), and the towing technology Ford put into the 6.0, it's an amazing piece of techology that out performs it's predecessor.
Problems arose in the early days becuase of the fuel available at the time. (Low Sulfur Diesel vs Ultra Low Sulfur diesel available today) LSD was potent stuff that gave great fuel economy and power to any diesel that ran it, 6.0 folks in the early days were averaging high teens and into the 20s without a chip or programmer. The problem with the 6.0, however, was the EGR. The fuel was considered "dirty" lead to carbon build up in the EGR system and plugged critical sensors like the EBPS and MAP. (both are required for the engine to run properly) With the advent of ULSD, this is considered to be a cleaner fuel, however, it has less power and offers less fuel economy. So the EGR and sensors plugging with carbon, isn't as prevalent as it used to be. The other part was due to lack of maintenance, not following the maintenance schedule, and people not using Motorcraft filters when maintenance is performed. In the early days, filters were expensive and as a result, people went to knock off brands as they were cheaper. After finding quite a few warranty claims due to using non-motorcraft filters (mainly failing injectors and sometimes catastrophic engine failure with the wrong oil filter), Ford reduced the pricing of filters and also found that the warranty claims related to not using the correct filters dropped. Flashes were developed to address some of the other issues, but the aforementioned is what gave the 6.0 the bad rap it has/had. Since then, these concerns have long been address and solutions to the 6.0 issues have been found and improved.
On to the 7.3: It's a tried and true workhorse that needs almost nothing but maintenance. Though it's a tried and true workhorse, the 7.3 does have some room for improvements over engineering flaws and things Ford should've done with it, but didn't. Most of the solutions to these flaws come from a Crafty individual named Clay, owner of Riffraff Diesel.
-The stock fuel system is a dead head style that leads to fuel starvation on the #8 cylinder. Ford and International had a work around for this by installing a long lead injector that essentially takes two sips of fuel before it fires. (the rest only take 1) Even with this work around, #8 sometimes still starves for fuel and makes that apparent by cackling and knocking. The solution to this problem, Riffraff Diesel's Frx or Fuel Crossover: Fuel Rail Crossover? (FRx) - Riffraff Diesel Performance The benefit is four fold: it solves the deadhead issue, creates a regulated return, AND maintains better fuel pressure for better injector life and performance. It also doesn't allow air to reach the injectors after a fuel filter change or during normal operation. It's a very cost effective solution to fix something that should have been addressed.
-Riffraff Diesel also sells a High Pressure Crossover rail that balances the high pressure oil between the head: Stainless Steel HPX 99-03 - Riffraff Diesel Performance This allows for better, smoother starts and throttle response. It also allows the ICP to be more consistent as it's seeing a more balanced pressure and the pressure in both heads and not just one.
Since you're after reliability the above mods are what I'd suggest if you decide to go though with buying a 7.3. As I've mentioned before, the 6.0 stock will run circles around a stock 7.3. This can be addressed with a chip, however and again, since you're after reliability you may not need to do all this as your truck may average great fuel economy in it's stock form. My Advice should you go the 7.3 route: drive it through 2-3 tanks, see how it does, then go from there.
Absolute Bottom line: Drive both and see how you feel about them. You can find a good 6.0 that will give many years and miles of trouble free service. The same applies to a 7.3, which brings me to my next point: if you need me to look at a vehicle (6.0 or 7.3) in the surrounding Houston area, I'll be more than happy to. I have an AE and a gauge to tell me if the EGR cooler or headgaskets are blown, so you're covered on both fronts. I'm well versed on both engines as I've done my fair of work and reading on them. The 7.3 will require less inspection, but it's always good to run the AE on it to see what underlying issues may be present. Either way, you can't go wrong, it's just a matter of making sure what you're buying is in good shape and/or knowing what needs attention.
Thanks Matt!
In addition to my post Matt quoted, I'll add a few other things:
-While the market is saturated with people that can tune the 6.0, it boils down to a select few that have proven to be masters at the craft of tuning the 6.0:
-Matt Robinson, Gearhead Automotive Peformance
-Eric Eldreth, Innovative Diesel Performance
-Tony Wildman, Total Diesel Performance
There are others, but if you browse the forums, you'll find that these are the top three tuners for the 6.0
-A 4 inch exhaust will make any 6.0 happier as it has more room to exhale. It tends to make more of a difference on a tuned truck rather than a stock truck though.
-Whether or not an intake should or should not be used on a 6.0 is a matter of opinion. The stock setup is good to 500hp and does a phenominal job of keeping dirt out of the engine. A cold air intake just flows more air using a different type of filter. I have an Afe Stage II Si on my truck and it's very happy with it especially with the hot tunes I run, little to no smoke.
-Depending on the quality of fuel I happen to get, my truck averages 14 mpg city and as high as 18 mpg highway, which equates to 16-17 mpg combined as my truck is equipped in my sig. As I've learned, your results may vary depending on the mechanical condition of your truck. Locked hubs, stiction, stuck slide pins, stuck or sticking calipers, damaged FICM, sticky turbo, are all things that can affect mileage and power. The amazing thing about the 6.0 is that its VERY smart and incredible at compensating for failing or damaged sensors until it eventually fails.
4EXTRDR
Nov 22, 2008 01:41 PM
goldsmje
Mar 9, 2008 09:59 PM
