dropping brake pedal
Old Jul 15, 2003 | 12:14 PM
donkeychop0009's Avatar
donkeychop0009
sometimes my break pedal drops just enough to keep the brake lights on and only when the truck is off. I don't have power brakes and the fluid level doesn't change therfore no leak? Any ideas?
Old Jul 15, 2003 | 01:48 PM
beartracks's Avatar
beartracks
You might need a return spring under the dash. Cannot remember if there should be one there or not.
Old Jul 15, 2003 | 02:41 PM
laptopgeek's Avatar
laptopgeek
donkeychop0009 ~
If your F-100 is like mine, look up under the dash - you should see a brake switch there - adjust it so it is not activated when the pedal drops.
I'd drag a flashlight up under the dash with me too....you might see something worn out in the brake linkage that needs to be replaced...
