Sponsored by: Real Truck
LED bulb "indexing"
Old Oct 3, 2014 | 10:29 AM
eberlestock's Avatar
eberlestock
LED bulb "indexing"
I put the cree led bulbs in my 2012 superduty. The passenger bulb puts out awesome light and delivers it in the right spot. I have no idea where the drivers side light is going? Its dark in front of the truck and against a wall they both look the same. I do see that the inside of the 2 light housings have different parts of them lit up inside? I tried turning the bulb in the drivers side so that it is oriented the same as the passenger bulb. I cant get it to match but it looks like I can remove the back of the bulb and turn it so that it sits right. Has anybody done this? Has anybody else even noticed this?
Old Oct 4, 2014 | 04:03 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Are you talking about headlights?
The bulbs are probably lighting of either LEFT/LEFT RIGHT/RIGHT LEFT/RIGHT or RIGHT/LEFT.
You will have to play with bulb orientation gets you the best results. But first.
Aim your headlamps.
Old Oct 4, 2014 | 09:47 AM
eberlestock
Yes these are headlights. I have tried every combination available and cant get the driver side bulb to sit the same as the passenger side bulb. This is why I am going to take the bulb apart to orient it. The lights were perfectly aligned with the halogen bulbs and both shine on the wall in the same spot. When I back up from the wall the drivers side light disappears!
Old Oct 8, 2014 | 09:29 AM
eberlestock
I finally got them dialed in. It took a lots of trying different combination. I finally swapped the bulbs side for side and got them right. This is a worthy upgrade for the $150 I spent. Light output is about double from stock halogens.
troverman
Dec 29, 2020 07:19 PM
dx3
Aug 20, 2017 09:30 PM
newtuner
2004 - 2008 F150
Apr 8, 2009 10:03 AM
SShank42
General Automotive Discussion
Jul 14, 2007 08:03 PM
Alicia
Electrical Systems/Wiring
May 1, 2004 11:52 PM
