explorer blower motor issues
Old Sep 29, 2014 | 05:20 PM
thefox48's Avatar
thefox48
Hi all
Quick question, My 2006 explorer has wound up with the heater blower running all the time. When you toggle the blower switch up and down you can see the light bar on the switch move the bars from low to high but has no effect on the blower speed. You can not get it to shut down even by turning off the heater or ac controls??
Any one run into this before?
Thanks
Larry
Old Sep 29, 2014 | 10:14 PM
shorod's Avatar
shorod
Does your Explorer have the electronic automatic temp controls? It sounds like it does, and if so, the blower motor issues could very likely be due to a faulty solid state blower motor speed controller. With the electronic controls it uses a transistor speed controller versus the old-school resistor and the transistor might be shorted.
-Rod
Old Oct 1, 2014 | 02:57 PM
weross67's Avatar
weross67
Good One
Does it turn off with the ignition?
Old Oct 1, 2014 | 06:06 PM
thefox48's Avatar
thefox48
The blower shuts off when the key is off. As soon as you start it up the blower comes on full speed.
Larry
Old Oct 1, 2014 | 09:04 PM
weross67's Avatar
weross67
Exclamation Great
If you set the function selector switch to the off position the fan should stop if not remove fuse F2.30 5A in the central junction box. If it continues to run you have a bad Blower Motor Relay in the BJB, if it stops you may have a bad Function Selector Switch. it is not a great problem to remove the panel the switch is mounted on or to change it after getting to it. Good luck!
Old Oct 20, 2014 | 07:51 PM
thefox48's Avatar
thefox48
Yes it wound up that the slector was bad. All o.k.
Thanks to all.
Larry
wpannone
May 9, 2016 09:56 PM
dessmo
Feb 14, 2016 11:01 AM
blloyd
Nov 1, 2009 07:32 PM
Mark~T
Jun 26, 2008 12:29 PM
pancake
Oct 26, 2003 10:06 PM
