Instrument cluster lights KAPUT
Old Sep 29, 2014 | 08:21 AM
TomFL's Avatar
TomFL
My gauge cluster lights quit, not seeing any blown fuses....Am I in for a rat's nest of electrical problems trying to figure this one out?
Old Sep 29, 2014 | 08:47 AM
Twitchyleprechaun's Avatar
Twitchyleprechaun
I hate electrical crap. If no blown fuses, I would want to see if there is a problem with the cluster next before I start tracing wires. Find a buddy with the same truck and see if they are willing to let you hook theirs up to see if everything is working. I am sure someone has a little more experience in this department then I do, but that is the route I would go.
What area you live in and what year and engine do you have?
Old Sep 29, 2014 | 10:36 AM
Plex's Avatar
Plex
With stuff like that I always check the fuses (like you did) then check the ground for the cluster, after that I'd check the B+ to the cluster lights and troubleshoot from there... seems like 75% of the time its the ground though... On all vehicles, not just the EX.
Old Sep 29, 2014 | 11:29 AM
TomFL's Avatar
TomFL
How would an automotive electrical layman like myself go about checking the ground for the cluster?? Where's it located?
Old Sep 29, 2014 | 02:05 PM
jpr38057's Avatar
jpr38057
Have you checked to make sure the dimmer on the headlight switch isn't turned all the way down?
Old Sep 29, 2014 | 02:45 PM
TomFL's Avatar
TomFL
Don't laugh but I didn't think of that initially... yes I eventually did check it
Old Oct 20, 2014 | 11:38 AM
TomFL's Avatar
TomFL
I've checked for chafing/corrosion on everything at the tail light end, sprayed corrosion block in all terminals and still nothing....
Anyone know of a way to check the dimmer switch before shelling out $80 to find out that's not it??
Old Oct 20, 2014 | 12:22 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Does the dimmer switch still control all of the other lights on your dash (radio, climate control, etc,)?
Old Oct 20, 2014 | 06:24 PM
TomFL's Avatar
TomFL
Oddly, no it doesn't. Those lights remain constantly bright no matter how I turn the brightness wheel. It will however, still turn my overhead light on and off if that helps.
Old Oct 20, 2014 | 07:41 PM
Misky6.0's Avatar
Misky6.0
so you are turning headlight switch to ON, not to auto, if so equipted?
Your headlights do turn on?
Tail lights and side markers on too?
How about door switches, the window and door lock switches are all backllit when you have lights on, so are the rear defroster and disable backup sensor switches.
What year and engine?
Old Oct 20, 2014 | 10:14 PM
Apocalypse's Avatar
Apocalypse
Tomfl, where are you located? In Fl. I assume...
Old Oct 21, 2014 | 11:46 AM
CircuitBoardMedics
For what it's worth, I just checked our 2004 Super Duty (6.0L) by removing the cluster altogether and seeing if the dimmer switch still controlled the remaining dash lights. The dimmer switch did still work properly and dim the radio/climate controls, etc. with the cluster removed. I hope this helps.
Old Oct 21, 2014 | 01:20 PM
TomFL's Avatar
TomFL
What I think I'm going to do is to pull the switch and check it with an Ohm meter and see if I'm getting any variation in Ohms when working the dial.
Will post up what I find, seems this might be a common thing.
I hope it is just the switch, that's an easy fix.
Old Nov 1, 2014 | 04:18 AM
TomFL's Avatar
TomFL
Follow up to put this one to bed: My light issue was caused by two things, a blown #17 fuse which was caused by a shorted/blown tag light.
Everything's back to normal.
Hope this helps someone else on the forum
Old Nov 1, 2014 | 08:54 AM
Misky6.0's Avatar
Misky6.0
Reps, for posting up the resolution.
