Emissions failure - Help Diagnosing
Old Oct 24, 2014 | 10:39 AM
  #31
az_r2d1's Avatar
az_r2d1
What Vwags said. Check the in and out temps. Outgoing temp should be higher than ingoing by quite a bit due to the chemical process.
If your truck is not obd2 (check sticker under the hood) this will never be detected by the onboard hardware.
obd2 trucks have an o2 sensor after the cat which would indicate a malfunction if there was one..
Old Oct 24, 2014 | 01:17 PM
  #32
Pele's Avatar
Pele
All vehicles after 1996 are OBD2 compliant, right?
As it was stated here, only California tricks have the downstream O2 sensor.
Old Oct 24, 2014 | 01:31 PM
  #33
Archion's Avatar
Archion
Veteran: Marine Corps
Over 8500k it's more of a blend of I and II, some sensors are in a permanent not ready state because they simply aren't there. It does have an OBDII port. It can really confuse the uneducated "techs"...
Old Oct 24, 2014 | 01:40 PM
  #34
az_r2d1's Avatar
az_r2d1
Not the excursions due to the higher GVW rating. Only California and some other models are obd2 I think. Sticker under the hood will tell you.
Charlie Tee
1983 - 2012 Ranger & B-Series
Sep 16, 2015 06:25 PM
bigtrailertower
Modular V10 (6.8l)
Nov 18, 2007 06:46 PM
DaJazzGuerilla
Modular V10 (6.8l)
May 15, 2006 10:38 AM
pcmenten
Aug 10, 2002 10:40 AM
