Foxbody mustang rear end?
09-25-2014, 08:33 PM
Any issues with running a 8.8 from 90gt. Measures 59.5" and is centered with equal lengh axles. Obvious i would cut off brackets and weld on new perches
09-25-2014, 11:09 PM
on
Sounds about like an explorer width. You will probably need to use spacers as stock was around 61.5" I believe.
09-26-2014, 08:14 AM
Fox bodied Mustangs (and Capri's) were introduced in 1979. Make sure it's an 8.8 because many of these cars came a 7.5.
09-26-2014, 02:42 PM
It is an 8.8. For sure. I just dont want to run spacers
09-26-2014, 03:03 PM
on
I have a 56 with an 8.8 explorer rear with 235 75 15 and stock ford car wheels, the tires rub the inside of the box.
craig
09-26-2014, 03:12 PM
Thanks for the info. I am doing some research and see that the explorer axles are offset. Being a truck i am sure i doesnt effect anything since there is no tranny hump like a car. Did anyone have issues with this?
09-26-2014, 06:16 PM
on
We were just discussing this in another thread. The offset pinion is not an issue. I'm running spacers on my F1, no problems.
09-26-2014, 08:00 PM
You do know a 1990 foxbody Stang would have 4 lug axles right?
09-26-2014, 08:01 PM
Not if they were swapped out with ranger 5 lug axles
09-26-2014, 08:43 PM
You are still better off with the Explorer rear. It's much stronger then the Stang diff.
09-26-2014, 09:06 PM
I agree. They are 31 spline axles. Thank you for the help. I have plans to sell this one and then buy a explorer rear for cheaper.
Daddyo's garage
05-10-2014 09:01 PM
Squeak51
06-13-2005 11:44 AM
CanadianCobra
12-11-2003 02:11 PM
Mush's 88
1978 - 1996 Big Bronco
11-16-2003 07:49 PM
