gauge cluster removal
Old Apr 20, 2002 | 10:50 PM
jbecker's Avatar
jbecker
Post gauge cluster removal
1995 F-150: Like an idiot, I removed the gauge cluster to replace a bulb, then hooked it back up and now the truck won't run correctly. Is this a computer issue? Please help! Mark
Old Apr 21, 2002 | 09:18 AM
MustangGT221's Avatar
MustangGT221
If you have dual tanks, did you plug in the switch? If you unplug the switch, it will turn over but not start because the switch stops the fuel pump. Did you mark the direction of the way the plugs were mounted in the back? Maybe you had one reversed, but i doubt that will not make the engine start. I have a good feeling that its the switch because that is the only thing that will cause the engine not to start if you fittle with the gauges and they are all plugged in.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Apr 21, 2002 | 10:07 AM
jbecker's Avatar
jbecker
THANK YOU! You were right! Hadn't put the trim piece back on because I wanted to see if everything worked so the dual tank switch wasn't plugged in. What a great forum! Mark (and thank you from Judi who yelled at Mark for messing with my truck!).
Old Apr 21, 2002 | 03:49 PM
MustangGT221
No problem, thats what we're here for.
Primary rig is:
Then theres:
Old Apr 21, 2002 | 03:57 PM
cajunbuck's Avatar
cajunbuck
roach711
Apr 11, 2012 06:04 AM
f100tk77
Apr 13, 2006 08:17 AM
JBronco
1978 - 1996 Big Bronco
Oct 9, 2004 02:44 PM
GeneStoner
15
May 16, 2004 08:05 PM
Nathan
Jan 14, 2003 09:46 AM
