Hood deflector
Old Sep 24, 2014 | 06:54 AM
purplewg's Avatar
purplewg
Hood deflector
So, when I ordered the truck I ordered the hood deflector. It is a dealer installed item. I think it was $88. So they put it on in a mere 2 hours while I stand around. A few days later I started up the interstate to the farm and noticed daylight between the hood and deflector. Before I could get to a turn off place it was up there flopping in the breeze. The double back tape came loose. I assume they did not clean the hood where the tape goes and it did not stick. Now I have to waste more time taking it back to be reinstalled.
Anyone had problems with their deflector? Will it stay if they do it right?
Old Sep 24, 2014 | 07:22 AM
jonrjen's Avatar
jonrjen
To be honest I can't ever recall seeing the latest body style with a hood deflector. If you get the opportunity to snap a photo when you get it back I would sure like to see how it looks.
As for the double stick tape that most manufactures supply on such like items, it is a joke. It is usually so thin that if affords little strength, the adhesive power is there but not up to the task required to hold.
When I order anything that requires the use of a double sided adhesive tape I add to the supplied tape or replace it all together with a automotive professional grade double sided 3M tape. It holds and has never failed to do so.
Good luck on getting it fixed
Old Sep 24, 2014 | 08:00 AM
ruschejj's Avatar
ruschejj
What does a hood deflector do?
Old Sep 24, 2014 | 08:01 AM
purplewg's Avatar
purplewg
I will get you a pic. The tape was actually pretty dang thick and looked like emblem tape that should work. I just don't think they cleaned first. They left hand smudge prints all over the front of the truck also. This time I plan to tell them to wipe it off after they are done drooling on it.
Old Sep 24, 2014 | 08:03 AM
purplewg's Avatar
purplewg
Well, some call them bug deflector but they really don't deflect bugs. We have so many love bugs down here and they will eat your paint. I got it to keep the love bug guts off the front edge of the hood.
Old Sep 24, 2014 | 09:34 AM
jonrjen's Avatar
jonrjen
Yes Sir, I have had the displeasure of dealing with "Love Bugs" and can't say that I enjoyed it one little bit!
Old Sep 24, 2014 | 10:53 AM
my_crib_too's Avatar
my_crib_too
Several trucks and many years ago I had a deflector and couldn't answer this question so I stopped adding them to my new trucks. I think this is a good question.
Old Sep 24, 2014 | 11:24 AM
purplewg's Avatar
purplewg
You may not need one in your state. Down here the Love Bug guts will eat the paint right off the front of your hood without one.
Old Sep 28, 2014 | 06:38 AM
purplewg's Avatar
purplewg
Ok, I went back into the dealer on Friday. They reinstalled my bug deflector with some 3M tape. Yesterday I go drive it and it looks funny. I get out and look and it has come loose in an area about 15 inches across the hood. I am about ready to just take it off and just keep the bug guts off the hood by hand. That or just buy my own and install it myself.
Old Sep 28, 2014 | 07:30 AM
jdadamsjr's Avatar
jdadamsjr
I would ask for my money back and go get your own...
Many have tabs that wrap around the front edge and use existing holes underneath to bolt in place...
OR, just get the protective film for the front of your truck and keep a good coat of Rejex on it... that's what we use on the rv's
Old Sep 28, 2014 | 09:57 AM
69cj's Avatar
69cj
The factory deflector on my 05 bolted on underneath the hood.
Old Sep 28, 2014 | 11:22 AM
purplewg's Avatar
purplewg
My 04 did also. This hood is flush with the back of the grill. Sits down on the rubber. No way to wrap around under the hood.
Rejex is probably the way to go.
Old Sep 28, 2014 | 12:20 PM
Gearitis's Avatar
Gearitis
Actully a lot of study on the imfamous acrylic bug deflector and it has been reported that it docks as much as 5% of your fuel mileage at Interstate speeds. I can attest to this, on my ole 2001 F-150, I had one on there for 3 years and then took it off and I had a noticeable difference in better fuel economy on the highway as it had a 4.6l. On our diesel trucks with the pretty square front ends I don't know if there would be that much change.
Old Sep 28, 2014 | 01:43 PM
elee3's Avatar
elee3
Since the front of the hood is kinda tucked in behind the grill, I don't get many bugs hitting the hood. And yes, I am in Florida dealing with love bugs. They are the primary reason that I don't want painted bumpers and grills. Chrome is impervious to bug guts.
Old Sep 29, 2014 | 07:24 AM
purplewg's Avatar
purplewg
I think I will just take it off and have them refund my money and put some Rejex on it.
