Aerostar Ford Aerostar
The Code Culprits
Old Sep 23, 2014 | 08:32 AM
Jose A.'s Avatar
Jose A.
The Code Culprits
finally found the reasons for the two Codes in my '97 4.0
yes, I know, took a while, but I am not an expert like you guys.
here are the culprits: Code P401 DPFE Sensor, found it on eBay. (The metal case sensor, nos)
Code P1443 Evap system Purge Sensor (also eBay)
Finally, CEL is off after replacing both sensors above.
Now I have to figure out the REAR ABS light, still ON.
Old Sep 23, 2014 | 05:20 PM
xlt4wd90's Avatar
xlt4wd90
I've seen many cases of test errors pointing to these devices. Was it because the EGR was badly designed/implemented on the Aerostar's first and only year to use it?
Old Sep 23, 2014 | 05:28 PM
Jose A.'s Avatar
Jose A.
don't know but I never had CEL codes with my 1992.
Old Sep 23, 2014 | 07:35 PM
87&97Aerostrar's Avatar
87&97Aerostrar
My 97 3.0 has had a piece of black tape over the CEL for five years. No noticeable difference in performance or gas mileage.
Old Sep 23, 2014 | 08:17 PM
Jose A.'s Avatar
Jose A.
the CEL is a conspiracy to make money from car owners
Old Sep 25, 2014 | 04:41 PM
jetfiremuck's Avatar
jetfiremuck
I had replaced 2 and finally gave up. The issue is that moist exhaust when cold and temp changes seem to ruin them. I checked my egr with a vac pump and it stumbles the engine so its working. I too plugged the egr vac hose over 100k ago, no issues so far.
Old Sep 28, 2014 | 10:25 AM
Kruse's Avatar
Kruse
I had to replace the same item on my Mustang a few years ago. I can't figure out what they put into those things to make them so expensive. Even the generic brands, which I don't recommend, are expensive.
Old Sep 28, 2014 | 04:23 PM
Jose A.'s Avatar
Jose A.
everything is made in China, including "OEM", so there's no difference nowadays.
stevenjf88
Jun 16, 2015 08:03 PM
Tennesseepowerstroke
Mar 22, 2010 10:28 PM
mhamrick56
Feb 22, 2010 12:12 PM
mzdb4000
1983 - 2012 Ranger & B-Series
Feb 3, 2008 12:50 PM
