Sponsored by: Real Truck
02 front parking lights issue
Old Sep 22, 2014 | 07:57 PM
rollin_coal's Avatar
rollin_coal
Ive read in forums that the dash, parking and taillights can all go out at once if the ??? Module goes out but im having a different issue. Just my front parking lights go out.sometimes just till the next time I drive or currently they havent worked for the last 3.days. turn signal still works, Taillights, dash lights etc, just the inner and outer front parking bulbs randomly dont light up?
Old Sep 22, 2014 | 08:09 PM
Modularation's Avatar
Modularation
GEM module is what you are talking about.
Have you added LED replacement light bulbs to front or rear?
Old Sep 22, 2014 | 08:28 PM
rollin_coal
Yeah I knew it was something like that just couldn't think of the letters. I added some spyder led taillights but havent had any issues and no hyper flash etc. If I remember correctly I had the issue before the taillight swap.
Old Sep 22, 2014 | 09:22 PM
Modularation
I got the hyper flash from adding a pair of LED 3257 bulbs in the rear. What do you know about this? If it can cause damage I need to get them out quick.
Old Sep 22, 2014 | 09:52 PM
rollin_coal
Its just a nuisance, I drove my old jeep for awhile like that and this truck actually had led bulbs in the stock lights that caused hyper flash. As far a the tj jeep fix I modified the oem flasher relay following the directions from led taillights I bought, or in the same area you find led bulbs in the auto part stores there is some in line resistors you can wire in, havent used them but I know they work. They may also make a different flasher relay for our Ford's as I know they make them for tj jeeps now.the taillights I bought have the resistors built in so I didnt have a issue after the swap.
Old Sep 23, 2014 | 06:09 AM
Modularation
Thank you!
Old Sep 23, 2014 | 06:43 AM
Modularation
There is an open recall for "multifunction switch" for overheating and losing headlamps, brake lights, and directional turn signals. May not be your concern.
Old Sep 23, 2014 | 03:58 PM
rollin_coal
Anyone? Someone has to have had this problem. Could it be the headlight switch even though everything else works and the taillights and dash lights come on in the parking/running light position? All bulbs are new as I just did a 05-07 front conversion, no crazy aftermarket bulbs, just sylvania amber parking/signal bulbs and some sylvania headlight bulbs.wiring is all good shape and clean and the truck only has 113k.
Old Sep 23, 2014 | 04:05 PM
rollin_coal
I just had the truck to a dealer a little over a month ago for a full inspection and they didnt say there was any recalls but I'll double check.
Old Sep 23, 2014 | 04:26 PM
jesse5's Avatar
jesse5
3156 or 3157 bulbs?
Old Sep 23, 2014 | 04:36 PM
rollin_coal
Originally Posted by jesse5
3156 or 3157 bulbs?
Id have to look, but I got whatever the bulb chart on here/sylvania said. Why would the outer mini bulbs quit also, keep in mind they still work as hazards/turn blinking, just not running lights.
Old Sep 23, 2014 | 04:47 PM
rollin_coal
3156 or 3157 bulbs?
3157 bulbs
Old Sep 23, 2014 | 06:51 PM
jesse5's Avatar
jesse5
Those are the dual filament bulbs. I was concerned it may have the 3156 single filament bulbs which do not do two functions.
Old Sep 23, 2014 | 09:30 PM
projectSHO89's Avatar
projectSHO89
There is no such recall for a 2002 Super Duty.
LEDs won't have any effect on the running (parking) lamps.
The GEM module has nothing to do with the running lamps.
If the rear running and license plate lamps continue to operate normally when the front ones go out, that eliminates the headlight switch as a potential concern.
Uh, what did that entail?
Old Sep 24, 2014 | 07:28 PM
rollin_coal
Nothing with the wiring besides a headlight bulb conversion plug, otherwise a bumper, grill, header panel, and some harley headlights.
No wiring was touched, cut, spliced etc.
