Contemplating the move
Old Sep 22, 2014 | 10:12 PM
Unrealo4's Avatar
Unrealo4
So the regens cause the valves to weaken? Or do they melt them?
Old Sep 23, 2014 | 04:59 AM
senix's Avatar
senix
The valves in the first couple of years were not hard enough. So therefore they couldn't take the heat from the regen.
Now not all have failed but enough that we know about it.
Old Sep 23, 2014 | 06:01 AM
ruschejj's Avatar
ruschejj
I'd say stay away from a 2011 and a 2012 if you can. The ideal trucks would be a 14 or a 15.
I'm about to sell my 2011 and it has had plenty go wrong with it. Our company had a 2011 6.2 truck too and it was reliable but had to go. We now have a '14 6.7 and my '15 6.7 is on order. I have to say, the '14 is a lot different than my '11. Remarkable actually, the 14 is a darn fine truck and I'm very impressed with it. So much so I'm real anxious to see what the 15 is all about.
Old Sep 23, 2014 | 10:30 AM
clem1226's Avatar
clem1226
Originally Posted by FORDTUF1
The HPFP some would say is a debacle, just ask someone that had it fail and see if Ford stepped up! Many, many people now use fuel additives every fill up.
Were changes made in the 13 and up model years to the HPFP or the filtration?
Old Sep 23, 2014 | 10:34 AM
senix's Avatar
senix
No changes to the 2013.
Proper changing of the filters and draining the separator regularly and buying fuel at high volume places is all you have.
Will be the same for 2015/16 models as well.
Old Sep 23, 2014 | 01:10 PM
Unrealo4's Avatar
Unrealo4
So eliminating the regens should help with that?
Old Sep 23, 2014 | 03:12 PM
mikeybfromtn's Avatar
mikeybfromtn
Originally Posted by senix
do what you are told
HA!!! Exactly!
Old Sep 23, 2014 | 05:02 PM
Thom12's Avatar
Thom12
Originally Posted by defyrftr
Mine told me new truck or new camper. I heard bigger truck means big 5th wheel.
If you work it the way I did, you can have both! Wife wanted a 5'er so we bought one. Went to pick it up using my '96 F-250 with a 7.3 and she drove it half the way home. She made the comment that she wondered if the truck would leave us stranded because it was almost 15 years old. I told her maybe, maybe not. She then surprised me and said that I was not gettting a new truck unless I special ordered it exactly the way I wanted...... one week later as soon as the order banks opened for the 2011's mine was placed on order.
As far as the OP's question, I have had a few issues with my '11 truck such as shifting (fixed with new solinoids) composite oil pan leak (fixed with new metal pan) and radiator leak (fixed with new radiator) all covered under warrenty. The only issue that I have not had any luck with is my limited edition rear end bounce at 40-45mph, but most trucks do not have that issue so I would not hesitate to purchase another 6.7 SD.
I would put buying a used 2011 or 2012 on par with buying any other used vehicle.... do your research, know what the vehicle is about, get a copy of the OTIS from a Ford dealer for the VIN you are looking at so you know the history, and lastly, let the buyer beware!
Old Sep 23, 2014 | 08:39 PM
Unrealo4's Avatar
Unrealo4
Well the chances of the valve failure seems to be very small. Every 6.0 ran the chance of blowing off a injector tip. Also everyone also could lose a lifter bearing into their lpop. Effectively casing catastrophic engine failure. I'm willing to bet either one of those problems were 10 times more likely then losing a valve on the early 6.7s. And they were pretty rare but did happen.
Old Sep 24, 2014 | 12:28 AM
DbigD's Avatar
DbigD
Just sold my 7.3 in my sig.
The dealership near by has two new 2013 6.7 F250s on the lot.
They are at a great deal but for $5K more I can get a 2014. Is it worth the difference or did all the kinks get worked out by 2013 on the new diesels?
Old Sep 24, 2014 | 05:13 AM
senix's Avatar
senix
I have a 2013. Just over a year now. It has been great. Just oil and filter changes. Nothing more.
By 2013 they seem to have the tranny and the valve issue and the turbo issue fixed.
I'd get the 2013 if it fits your current and future needs.
If you are going to tow heavy though I would be looking at the F350 so you can get the overloads.
2.5gl
Apr 10, 2016 09:10 PM
Mr. Sandman
Feb 20, 2015 12:35 PM
h20ford
Dec 3, 2012 10:10 PM
slow rider
Sep 13, 2011 02:45 PM
josh46044
Oct 24, 2003 04:13 PM
