Sponsored by: Auxito
99 Econoline Aux. Battery
Old Aug 23, 1999 | 07:55 AM
Jim_1's Avatar
Jim_1
My 99 Econoline has an auxillary battery. The owner's manual says very little about how to access it, for example, running 12v equipment off it when camping, etc. The aux. battery is connected to the van's 7 spade bargman electrical plug (tow package) but when I put electrical test on connection to plug, it shows no juice. Help, please!
Old Aug 12, 2002 | 10:58 AM
rockclimber_tx's Avatar
rockclimber_tx
Is the relay installed for the Aux battery? Make sure all
of the relays/fuses are installed in the Central Junction box
in the engine compartment.
Have you tested the aux. battery? My service manual shows the
aux battery on a '99 to be located on a frame member on the RH
side of the vehicle.
Mike
Old Aug 13, 2002 | 10:19 PM
wolfmanagh's Avatar
wolfmanagh
I came across a problem were the isolater relay under the hood battery quit working so I just bypassed the relay. Don't really need that one anyways.
This is in a cutaway bus. So the bus builder ran a cable from the frame battery to another relay that also works with the ignition for all the rear accesories. And these are heavyduty relays too. their like 95continues ampers. Not a starter relay which can overheat and fail if used as a continues relay.
Old Aug 14, 2002 | 06:21 PM
HiTech's Avatar
HiTech
If all is hooked up right, with the engine running the aux battery should be charged by the alternator, but with the engine off the aux battery should be isolated from the chassis battery.
-Jim
2001 E-450 v-10 Superduty
Old Aug 14, 2002 | 06:23 PM
HiTech's Avatar
HiTech
23larry24
13
Apr 9, 2019 10:07 AM
mandingo626
Apr 29, 2015 02:10 AM
irishinontario
Jan 15, 2014 08:33 PM
icentropy
Jan 12, 2014 03:56 PM
CassB
Dec 30, 2013 09:38 AM
