Anyone using a Barder Billet compressor
Old Sep 26, 2014 | 04:00 PM
Don Naslund's Avatar
Don Naslund
The "extra" part, obviously goes under the oil seal bushing/bearing part on the compressor side but when I used it, the turbo would bind up. I had ordered both kits so It wasn't a problem for me. I think that those who hear the turbo whine, are using straight pipes, no muffler, no catalytic converter.
Old Sep 26, 2014 | 07:40 PM
Renron's Avatar
Renron
On the Road Again.....ba, ba, ba, bum. I'm on the Road Again
It's Alive! It's Alive!
The Pork Chop Express is back!
Still smokin' a little, but not bad.
As for the new Compressor Wheel, it is from Riffraff and Barder Turbo Service says so right on the back. Mine is #38.
I like it. Here's why.
It's quieter than the stock "Wicked Wheel" design of 6+6 blades.
It's quicker to spool than stock Compressor.
It has a different pitch to the whine. A touch higher I think.
The whine comes on about 800 rpm and is gone by 2,000. Keep in mind this is a noisy 7.3. And I've not yet gone past 2,000 rpm.
I have not "got on it" because it's still breaking in. So I cannot speak about how fast it spools above 8lbs boost.
I do not have a "tune" in it yet. Same reason as above.
I'll add to this thread after ~100 easy miles.
Ron
Old Jan 5, 2017 | 10:14 PM
10shots's Avatar
10shots
Renron
Originally Posted by Renron
Looking to buy a new and improved , type 2 or whatever you'ld like to call the newest breed of Billet compressor wheels. I would like to keep everything stock for reliability, just change the compressor wheel.
I've got an E99 but would appreciate anyone with one of the Barder wheels.
They seem to be a different design than RR's billet or the WW2.
Any info would be appreciated. Opinions welcome
Ron
how did the riffraff wheel work out on the early 99 ? I have a early 99 and trying to deside on ww2 or the riffraff wheel
Old Jan 6, 2017 | 09:06 AM
Walleye Hunter's Avatar
Walleye Hunter
Welcome to FTE 10shots. In a case like this it would be best if you start a new thread with a title that indicates what you are looking for/what your problem is. Many will pass over an old thread like this and you will miss out on their input.
Old Jan 6, 2017 | 10:56 AM
Renron's Avatar
Renron
Don't count out old posts not being relevant anymore.
I've now got +151,000 on my truck with ~20,000 on the newly rebuilt turbo.
I bought the complete kit, I would advise anyone else rebuilding theirs to do the same. It was uncomfortable as Hell to work on it and laying across the block wasn't any fun, but it was worth it!
It has performed flawlessly since it was installed. I must have put it back together correctly.
The boost does come on much quicker (lower RPM), it develops more boost overall (I've got a monitor set) and sounds different than the stock Whistle sound.
Sound wise it's more like a wine glass when you run your finger around the edge and it "rings". Very cool sound. Not as loud as the WW whistle.
I have pulled a 27' Travel Trailer and a very heavy aluminum river jet boat up some steep inclines with the truck and if you watch the temps and keep the RPMs up there is no problem. I have a 4 stage tune kit and keep it at +80hp boost. I have run the turbo all the way up to 23 boost and have not had a lick of problems.
I wanted to wait until I had some miles on the new turbo before reviewing the unit, I forgot to update with the results. I'm sorry.
Remember this wheel is lighter so it spins up faster and slows down quicker too. (less mass)
Very happy customer.
Ron
dogerbrown1
16
Jan 6, 2022 12:17 AM
Bob_T
28
Apr 17, 2019 11:23 AM
hotrodfeguy
Apr 1, 2015 04:58 PM
Dean88
Oct 17, 2011 12:05 AM
Spectre23
May 13, 2003 10:13 AM
