Solid Motor Mounts
Old Jul 14, 2003 | 07:30 PM
speedkingf100's Avatar
speedkingf100
Solid Motor Mounts
I have been cursed with motor mount trouble lately, I have broke three drivers side potor mounts, and it is getting annoying, as i only have a stock 302 2 barrel engine in my 1970 ford f100 and although it is no slouch it aint no torque monster either, so back to my question, if properly fabricated would solid steel engine mounts work (the mount that bolts to the engine block) to replace the stock rubber ones.
any help greatly appreciated
Steve
Old Jul 14, 2003 | 08:23 PM
Ford Truck Racer's Avatar
Ford Truck Racer
Solid Motor Mounts
Yes it should work. Remember that if you are going to mount the engine solid the tranny must also be mounted solid. Otherwise you could start breaking bellhousings.
Old Jul 15, 2003 | 11:10 AM
jpb222's Avatar
jpb222
Solid Motor Mounts
Why don't you chain the engine down?
I put one on my windsor with enough slack for normal driving withough using it then when launch hard the chain takes the force and the rubber doesn't break.
Old Jul 15, 2003 | 09:14 PM
speedkingf100
Solid Motor Mounts
thanks for the replies I just dont want a chain cluttering up my engine compartment
Steve
Old Jul 16, 2003 | 03:53 AM
Crossfire's Avatar
Crossfire
Solid Motor Mounts
You can also use a heavy-duty turnbuckle connected between the frame or crossmember and the engine block. Painted black, it wouldn't be noticeable.
Old Jul 16, 2003 | 04:22 AM
Torque1st's Avatar
Torque1st
Posting Legend
Solid Motor Mounts
If you mount the engine solid you will get a lot of vibration, -that is why they are mounted in rubber in the first place. You should not be breaking mounts tho. A broken passenger side mount can put stress on the opposite mount also. I have used a chain in the past on an old 500+HP 390.
Old Jul 19, 2003 | 11:44 PM
Big F250's Avatar
Big F250
Solid Motor Mounts
My truck originally had a 351/C6 in it. The previous owner swapped out the engine for a 79 460/4 speed and fabricated up some trick solid steel motor mounts. It doesnt vibrate at all. You cant even tell that they're is no rubber. I recommend this if you keep breaking mounts.
Old Jul 21, 2003 | 09:13 PM
JimmyDee's Avatar
JimmyDee
Solid Motor Mounts
Well, a few links of chain don't get in the way -- but, you know, there's something else causing this -- especially if it just started happening after 30 or so years of no trouble. And a light-tailed truck with a 2bbl shouldn't be twisting the engine off its moorings. The other motor mount or the transmission mount or....
Josh Hopkins
Oct 22, 2016 02:23 PM
oliverba54
Feb 29, 2016 07:41 PM
steve33444
85
Oct 28, 2015 10:12 AM
Silversubie
Jul 27, 2015 08:52 AM
FordManStan
Jan 3, 2007 08:34 AM
