05 Lincoln navigator no start
Ok guys my name is alex and like a lot I am new to the forum. I have a 05 navigator that has had a miss issue since I have owned it. Now I have tried everything In my power to sort the miss out.
Today I may have really messed up. I had the fuel rail off swapping some injectors around to see if I could pin point which injector is a possible problem. I had the idea that if I tried to start the engine with the top portion disassembled that maybe it would activate the injectors so that I could maybe see which one is not firing. Well of course nothing happened
So I swapped the good injectors for what I am thinking are bad injectors and put the whole thing back together. Well now the damn thing won't start. I turn the key it clicks like the engine is seized and the dash flickers at me in time with the clicks from the starter.
If anyone has any ideas it would be greatly appreciated. Jus need it to turn over. I can diagnose if it turns over but with this I am baffled. I tried to reset the pcm by unhook in the battery. But no luck. It started fine before the break down to the fuel rail, it just ran like crap.
Any help is appreciated I'll be looking around to see if I can offer advice else where
templarknight
09-12-2010 08:46 AM
