Another EBP sensor-failed!
Old Sep 20, 2014 | 08:58 PM
2006powerstroke90's Avatar
2006powerstroke90
Another EBP sensor issue!!
So, went to go out to dinner tonight get in the truck and the turbo isn't building ANY boost. Exact same symptoms as last time....
But this time it's a little different the sensor reading is 14.1 SOLID. it will not move wether I'm at idle or doing 50MPH. And the turbo is barking ALOT!
If I unplug the sensor it drops down to 6.4....
So, again, I assume this sensor has failed and will need to be replaced.
Anyone have any ideas why they keep failing?
Old Sep 21, 2014 | 12:07 AM
22fordguy's Avatar
22fordguy
Im on number three in less than 2 years all ford parts from dealer
Old Sep 21, 2014 | 12:27 AM
Yahiko's Avatar
Yahiko
Are all the tube support brackets in place?
Vibration would not be the best as it is with
the brackets in place but if they are missing
it could be a lot worse.
Sean
Old Sep 21, 2014 | 08:04 AM
cheezit's Avatar
cheezit
Replace the connector yet?
Parts is covered 12 or 24 months depending on when you bought it
Old Sep 21, 2014 | 03:10 PM
2006powerstroke90
Support bracket is perfect. New sensor and pig tail today everything is perfect!
Part was covered
Dave042
20
Feb 12, 2019 02:20 PM
Captn B
Aug 25, 2015 08:25 PM
fixxxer-upper
May 30, 2013 12:21 AM
6LPSD
Feb 28, 2009 10:49 AM
misterc
Mar 8, 2008 02:05 PM
