delay wipers problems
Old Jul 14, 2003 | 06:32 PM
nick11082001's Avatar
nick11082001
i just recieved a delay wiper system, switch, harness and black box from a 1986 Fseries and have put it into my 1982 F150 previously w/o delay wipers, high speed works, but low and the delay does not work, i hooked up the extra ground wire, and its still not working, what could the problem be?
Old Jul 14, 2003 | 06:47 PM
steve83's Avatar
steve83
Either one of them could be bad. With the wiring diagrams in the Haynes manual, you should be able to figure out which.
Old Jul 15, 2003 | 10:35 AM
Big Red's Avatar
Big Red
I added delay wipers from an '83 F150 into my '83 F100 and it was "plug and play"... they worked just fine. Plugged in the unit to the existing wiring harnes, hooked up the ground and bada-bing, bada-boom.... delay wipers!
I can't see that there would be a difference between an '86 and an '82 delay unit. Maybe the unit has a problem... did it work in the '86 before it was removed?
Old Jul 15, 2003 | 04:58 PM
nick11082001
i dont know if it worked or not, i got it off ebay, also, only hi speed on my wipers work, and they will not "park" at the bottom of the windshield when turned off, i was reading on previous threads that this could be the motor?
Old Jul 15, 2003 | 05:06 PM
5_labsownus's Avatar
5_labsownus
I picked up a 1982 F150 for parts and found that it had "delay wipers" and "head light alarm". Both were a plug and play with no problems!
Old Jul 15, 2003 | 06:45 PM
Big Red's Avatar
Big Red
If it won't park, I suspect the switch in the motor. I had a problem with the wipers on my Taurus that wouldn't park and it was the park switch on the motor, not the motor itself.
Old Jul 15, 2003 | 07:08 PM
nick11082001
ive read that the park switch is part of the motor on these trucks, and you have to replace the whole motor?
Old Jul 15, 2003 | 07:11 PM
Big Red's Avatar
Big Red
What happens when you put the old "non-delay" unit back? Does it work fine?
The delay unit I have was purchased off eBay also but worked fine.
Old Jul 15, 2003 | 10:50 PM
nick11082001
the old non delay unit works exactly the same, only hi speed, and will not park the wipers when shut off
Old Jul 15, 2003 | 11:27 PM
Mil1ion's Avatar
Mil1ion
Then you need to inspect the wiper motor & its ground.
Old Jul 16, 2003 | 12:02 AM
nick11082001
im sorry, but im kinda new to this, what do i need to look for when inspecting the motor and ground?
Old Jul 16, 2003 | 12:33 AM
Mil1ion's Avatar
Mil1ion
Click this & you should see 2 pages of wiper related threads.
https://www.ford-trucks.com/forums/s...der=descending
