Strange electrical problem
Old Sep 20, 2014 | 11:45 AM
RickardC's Avatar
RickardC
1980 F-250, 351M. Battery tests OK - 500 cold cranking amps. New starter, new starter solenoid. When I turn the key to ignition, small click under the hood on driver's side. Turn to start, the starter solenoid clicks once, but no turnover. After that, all electrical is dead - no lights, no horn, no radio, no clicks. Turn the key to accessory, gauges work, but no radio, etc. Turn the key to ignition, nothing.
Tried jumping from another car, and the cables melted. I'm baffled. Can you help?
Old Sep 20, 2014 | 03:09 PM
Ranger80's Avatar
Ranger80
Sounds like a bad connection somewhere. Clean all the connections and inspect your wiring.
Old Sep 20, 2014 | 03:41 PM
CountryBumkin's Avatar
CountryBumkin
Get a new battery-to-starter-solenoid cable, a solenoid-to-starter cable, and a new ground cable. That would cover all the bases. One of these is bad.
RickardC
Electrical Systems/Wiring
Oct 5, 2014 07:37 PM
Uncle Paul
May 22, 2014 09:33 AM
MBBFord
18
Dec 10, 2007 02:16 PM
4.9inline6
18
Mar 6, 2006 08:05 AM
vern
Feb 13, 2001 03:06 PM
