View Poll Results: how many have switched to the 100 amp alt
yes, done it
26.67%
maybe, thinking about
66.67%
no, leave it alone
6.67%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
100 amp alternator
Old Nov 3, 2003 | 01:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just pull the bolts and rotate. Don't pull the halves apart or you may damage some wiring etc.
Old Nov 3, 2003 | 01:26 PM
leov5's Avatar
leov5
the alternator that i got just so happen to fit with out turning it. but like Toprque1st said it is very easy to do.
leo
Old Nov 3, 2003 | 01:43 PM
Purely Ford's Avatar
Purely Ford
Sounds pretty easy then.
I am going to perform this alternator swap since I have a 1000 amp invertor I am trying to make use of. I think the two battery setup is a must to make this invertor more useful.
Old Nov 3, 2003 | 03:26 PM
ranger429's Avatar
ranger429
sometimes you will have to split the case completely to do a rotation. not hard at all, use a toothpick to hold the brushes in the retainer when reassembling. there is a small hole in the bottom case of the alt. to put the toothpick through, when assembled just pull out the toothpick.
paper clip straightened out works great also
Old Nov 4, 2003 | 12:45 AM
Purely Ford
I meant to say 1000 watt inverter not 1000 amp. .
Old Apr 9, 2009 | 04:48 PM
pugzbarbq's Avatar
pugzbarbq
100 amp okay?
I am thinking about putting a 100amp alternator into my ice cream truck to help run my freezer. The freezer needs 3400watts to get started, but drops significantly once it's running (I have a 3000w inverter with a 6000w peak). My deep cycle marine battery will handle the load, but my 55amp alternator has to really crank to recharge it. Since I make mostly short runs, this can be a problem. My battery has only died once, but I don't want it to happen again. Hence, the decision to up my alternator. My questions are: Is it a good idea? Do I need a different voltage regulator with the new alternator? Do I need any new wiring to handle the bigger load? Should I go higher than 100amp (I also have an 800watt stereo system)?
Old Apr 9, 2009 | 08:50 PM
kingford72's Avatar
kingford72
heres two things I use at the junk yard to pick out alt and how to wire them http://i649.photobucket.com/albums/u...2/DSC00292.jpg and http://i649.photobucket.com/albums/u...2/DSC00293.jpg
bghnkinf250
145
Oct 17, 2021 11:02 PM
steveamann
Jun 7, 2017 03:17 PM
Talltruck
Jun 6, 2016 12:55 AM
Texas Bob
Dec 6, 2015 09:44 PM
fast_st
Sep 5, 2006 01:11 PM
