cutting out.. Code P0306 Internal Control Module Keep Alive
Old Sep 19, 2014 | 06:47 PM
Diesel 724's Avatar
Diesel 724
I was hauling wood so i set my Infinity to 80hp ran great for a while until i started coming up a hill on the way home. It started spitting and sputtering wanting to die. I made it home saw that was the only new code ive never seen before.. put truck back on stock setting and started it again, still running funny. Asking for help? Dont wanna drive away and break down!! I was also low on fuel but not out.. just put 20 in now.
Old Sep 19, 2014 | 06:53 PM
AllaboutMPG's Avatar
AllaboutMPG
do you have a fuel pressure gauge. have you done the in-tank mods. using my phone so I can't see if there's a signature. what year model what kind of truck
Old Sep 19, 2014 | 07:00 PM
Diesel 724's Avatar
Diesel 724
00 F250 7.3 with DP infinity, so i can monitor and run some tests. Just dont know where to start. No fuel tank mods done as of yet.
Old Sep 19, 2014 | 07:04 PM
AllaboutMPG
I haven't looked up the code yet. my first suspicion is that your pick up foot may be broken off. I know I found mine broken off when I went to do the in-tank mods. that means you're not able to pick up all the fuel in the bottom of the tank and if it was low you could be experiencing fuel starvation. a fuel pressure gauge at this point would really help.
Old Sep 19, 2014 | 07:22 PM
Diesel 724's Avatar
Diesel 724
I added fuel it seemed to have helped, but still had the cose, just cleared it, gonna check it in a few after a small drive. I can do tests with the infinity, if i knew exactly what PID it was i could monitor it provided it was a readable PID from stock PCM...
Old Sep 19, 2014 | 07:36 PM
AllaboutMPG
I don't think that our PCM monitors fuel pressure. you can tap into the back of a fuel bowl and run a mechanical gauge. I've got a little electrical sending unit the feeds a gauge in the cab. that way if I ever start to lose fuel pressure all know it right away. a lot of guys will tap in with a mechanical gauge in the engine bay just for troubleshooting purposes. you'll need to test it at idle and under load. it may look normal at idle but as soon as you put a load on it or a demand that pressure will drop if the pump is weak or filters are clogged.
Old Sep 19, 2014 | 07:41 PM
Diesel 724's Avatar
Diesel 724
It seems to have cleared up and running better now that i added fuel, and the code i erased has stayed off for now.
Old Sep 19, 2014 | 08:19 PM
whitetmw's Avatar
whitetmw
P030 series monitors miss fires. P0306 is the #6 Cylinder. The PCM is capturing misfires on that cylinder.
Old Sep 19, 2014 | 08:21 PM
F350-6's Avatar
F350-6
Think he meant 0603 for the KAM error code.
Old Sep 19, 2014 | 11:06 PM
Diesel 724's Avatar
Diesel 724
Yea sorry forgot to mention that, it was KAM error.
Old Sep 20, 2014 | 01:06 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Does sound like time for Hutch and Harpoon mods. Here's a pretty good thread on the subject to get you started. Fuel pick up foot (or umbrella, thingamajig, whatever) is pn E5TZ-9J306-BA in case yours broke.
Old Sep 20, 2014 | 07:30 AM
Pikachu's Avatar
Pikachu
The P0603 will set if power to the PCM keep alive circuit is lost, like when the batteries have been disconnected. If you clear it and it comes back without having disconnected the batteries, I'd suspect a wiring problem.
Old Oct 13, 2014 | 01:53 AM
Diesel 724's Avatar
Diesel 724
Well update, truck runs normal for how it normally runs. But last i checked i still had the code! What causes this code and do i fix it?
Old Oct 13, 2014 | 07:15 PM
aawlberninf350
It's a Van Gogh
The code will stay there until cleared. It sets when batteries are disconnected. Check for bad connections at the batteries, corroded cables, etc. Also the power splice on the DS fender under the air cleaner, pic below. Not shown is the black plastic cover says high voltage. Should say high amperage but o well. That can rot away and get iffy.
The Infinity can do everything including clear that code. I don't have one but read around I bet it's easy.
Old Oct 13, 2014 | 11:33 PM
Diesel 724's Avatar
Diesel 724
I have cleared the codes. The day this all happened and i added fuel and it starting running right, i immedietly cleared them. Always have a light on from something so dont check it daily. Checked yesterday and it was back on. Batteries are clean and tight. No problem with the battery wires. Brand new alternator, and the charging system works... so i may have yo check that out... i just cleared codes again today... so after a drive tomorrow ill see if its back again...
