well getting ready to finish this. headman and hooker dont seem to have fenderwell exit. i really would not want to use chassis exit. any more leads? thank you.
Besides Mad Dog Doug Thorley is the only other fenderwell exit I now of for an FE F250 4wd truck .. So your going to have to lay out the $ or forget the idea ..
2x... not for an FE at least. Hooker does carry a set for 351M/400.
Have ya considered shorties like from Sanderson? $325 for plain steel.
The only problem I see might be the routing of the rear sump dip stick tube with the sandersons but that was an issue for me with the Mad dogs also but still doable ..
Just be careful.
They are bitch'en headers, but if you have a half ton you may have to do a bit of re routing to make them fit.
Steering, cab brackets, inner wells and oil dipstick are some areas of concern.
They seem to fall right on (qualified) to 3/4 tons.
