Random testing
Old Jul 14, 2003 | 03:08 PM
aj3z11's Avatar
aj3z11
Question Random testing
I recently purchased a 2003 F 250 crew cab 6.0 King Ranch. The truck had a sticker on the driver's door window stating that the truck had been selected for testing. Can anyone tell me what kind of testing was done on the truck. The odometer read 63 miles at delivery including a short test drive by me. I now have about 1500 miles on the unit and it has been perfect so far.
Thanks.
Old Jul 14, 2003 | 08:51 PM
The Diesel Dude's Avatar
The Diesel Dude
Random testing
Ford selects a few vehicles each day for an audit of quality. They call it a nova (I'm not sure what that acronym stands for). It is used to monitor current quality from their assembly lines and to see if there are problems that they need to look in to.
Maybe there is a Ford employee that can give us a more concise defination on this subject.
Old Jul 15, 2003 | 02:07 PM
Chronos_Titan's Avatar
Chronos_Titan
Random testing
Thanks.
Hey look on the upside at least you know that it passed!
Old Jul 16, 2003 | 03:38 AM
bmpmdf's Avatar
bmpmdf
Random testing
What happens is a test drive. There is a list of things the driver(tester) is looking, listening, feeling in road manners, etc. for. After the drive, the truck may be re"roll tested" depending on test drive evaluation by driver. Roll testing is done to every vehicle off the line. It checks to make sure engine/trans/electrical/computer systems are operating in a preset range of acceptibility. If your truck was selected for testing, I'm jealous!!! It was gone over with alot more care than the avg. vehicle. If anything was even remotely questionable, it was changed or repaired, then retested. It should be a higher quality truck for you. P.S., I work at the St.Louis Assembly Plant for Explorers/Mountianeers/ Lincoln Aviator's. A friend of mine does the road testing/evaluations there and has given me a little insight on it.
MUDBUCKET
2004 - 2008 F150
Jul 31, 2014 04:05 PM
KingRanchdrw
Nov 28, 2012 07:35 AM
H20hound
Jun 23, 2007 01:16 PM
t1956bird
6.4L Power Stroke Diesel
28
Feb 15, 2007 04:54 PM
KING
Nov 9, 2006 05:25 AM
