Holly one barrel help
Old Sep 15, 2014 | 11:33 PM
ihf-350's Avatar
ihf-350
We have a 63 f100 with a 223 and a holly one barrel it was rebuilt at the beginning of the summer and was running fine until Saturday now it will not idle/run without the choke pulled and there is a woosh that comes out of the carb when you hit the gas. When you open the choke plate by hand under the hood sometimes it will stay running if you open it with the **** it will die also when you hit the gas it will stumble then accelerate like it is supposed too
Old Sep 16, 2014 | 01:52 PM
tinman52's Avatar
tinman52
Welder User
Sounds like a vacuum leak. Did you replace the carb base gasket(s)? Could also be the vacuum advance can causing it to suck air.
Old Sep 16, 2014 | 02:18 PM
ihf-350's Avatar
ihf-350
I don't know if the base gasket was replaced this is my uncles truck last night I sprayed carb cleaner around the base gasket, the Im gasket, around the vacuum tube going to the advance, and the advance but no change in rpm
MrBlue6869
Aug 20, 2018 07:02 PM
79str8six
Mar 8, 2011 08:47 AM
f100help
Oct 13, 2010 08:00 AM
kevin71100
Jan 4, 2004 11:40 PM
RJOLLEY
Sep 28, 2003 04:33 AM
