Changing a turbo Wheel?
So I see lots of info out there in the cyber world about pulling the intake housing off and using an impact to pull the old wheel off. Then I read the websites of the folks selling the wheels and they say "DO NOT USE AN IMPACT TO CHANGE THE WHEEL" it can cause stress cracks and turbo failure.
I'm looking for experience from the brotherhood. Anyone out there have a turbo failure shortly after using an impact. What do you guys recommend.
Have already done the EBPV delete pedestal and bellowed uppies. don't have anything I need to do that requires pulling the turbo but will do it if there is a chance of damaging it.
Thanks,
Thanks,
I haven't seen that video before, but please take anything you see on powerstoke help with a huge grain of salt. While that did work in his video, you have to keep in mind that there's no oil flow to the turbo when you do that. The shaft spins just fine on the film of oil that remains in there, but repeatedly bumping it with an impact, especially if you hold the impact at a slight angle could lead to issues.
Not buying the 'lack of lubrication' argument. You experience the same lack of lubrication on a cold start. Only the turbo is spinning considerably faster at idle during that few seconds it takes for the oil pressure to come up. Especially with non-synthetic oils in colder climates which millions of trucks manage.
In my opinion, retailers advising against the practice is just good business sense. The less liability you retain with your product, the safer you will be. With how easy it is to mess up these kind of installs, you want to remove as many variables as possible. In their shoes, I would do the same thing.
on
This is a really good thread.
Have any of you seen thread issues with the Riffraff wheels? I'm planning to install their ported housing wheel. As safe as I think the impact method is, I wouldn't use it if there was a chance of a threading issue. That sounds like an easy way to spend a lot of money...
Mark
Mark
Besides, exhaust gasses tend to be a bit smoother at spool up than an impact wrench. I was talking about the impact breaking the surface tension of the oil with no other oil coming behind it to replenish, but everyone is free to do what they choose.
Some have used an impact with no issues, others have rebuilt or bought a new turbo after using an impact. Your turbo, your choice.
triton185
06-29-2007 06:09 PM
spitball
02-10-2005 05:40 PM
