6.0 hot start issues
Old Sep 14, 2014 | 05:45 PM
Lawrence83's Avatar
Lawrence83
Ok new to this so bare with me. Got a 6.0 diesel. Has arp studs, oem gaskets back in, coolant filter XDP, oem oil cooler, sinister egr delete, and sct livewire ts tuner. Usually in street mode. Also has revised stand pipes and dummy plugs as well as the STC fitting. Revised fuel spring. Running rotella T6 full synthetic. I pulled up to drive thru. Turned off my truck. And there it was. No start. Left it. Came back next morning. And cranked right up. Had hot start issue ever since. It's throwing a code for icp too low. And icp cranking too low. Icp is at 250-280 cranking. Once started it's at 580 idle. But very irratic. Shop told me it's the seals on the hpop. 1,300$ to fix. Sound about right?? And was wondering how to test the low pressure oil pump. Shop said its weak. Cause they took off the oil cap and cranked it and levels rise slower than he liked. Sound right??
Old Sep 14, 2014 | 06:13 PM
mustang_309's Avatar
mustang_309
What are the ICPV's at KOEO? The seals on the oil rail nipple cups can also go bad. 05' and up HPOP's rarely fail. So I wouldn't install a new one based on what you've stated here, I would perform an air test of theHPO system.
Old Sep 15, 2014 | 10:46 AM
Lawrence83's Avatar
Lawrence83
I do not know. But they aren't replacing the hpop. Just a seal that's somewhere down there.
Old Sep 15, 2014 | 12:07 PM
dr67's Avatar
dr67
What year is the truck? It could be the STC fitting at the pump, or stand pipes/ Dummy plugs. there are updated pcs for both of these.
Old Sep 15, 2014 | 06:57 PM
JeremyXDP's Avatar
JeremyXDP
SPONSOR
Could be the ball tube seals if it's a 04.5-07
__________________
Xtreme Diesel Performance | XDP
Call us @ 1-888-DIESEL4
Old Sep 16, 2014 | 09:26 AM
Lawrence83's Avatar
Lawrence83
As I said before I have already had all pipes and STC fittings revised. Shop called yesterday and they are replacing them again. Which I feel is just throwing parts at it.
AerialTech
Jan 15, 2018 11:47 AM
waistline00
Aug 26, 2017 06:24 PM
rowdyredneck
Jul 19, 2016 01:00 PM
mnwcine
Sep 3, 2013 10:16 AM
bigbubba87
Jun 2, 2012 01:43 PM
