NEED SOME HELP
Old Sep 14, 2014 | 03:23 PM
f350flatbedtruck2525's Avatar
NEED SOME HELP
I have a 2006 F-350 4x4 Dully 6.0L Power Stroke Diesel. Just got the EGR delete kit put on and SCT Programmer. The other week I had a battery go bad and always had to have someone jump start me I replaced both batteries in the truck. Everything was good then a couple days later my coolant reservoir got a hole in it and overheated the truck but soon as I notice the gage I turned the truck off and opened the hood to let it cool down. I ended up replacing the coolant reservoir, thermostat, top radiator hose, and the fan clutch. Then after all that the truck ran good for a couple days. But now when you start the truck it shakes at idol and when you drive it. So I brought it to auto zone so they could run a test on it. It through 4 codes: PO267- Cylinder 3 injector circuit low, PO683- Glow Plug Control Module to PCM communication circuit, PO672- Cylinder 2 Glow Plug Circuit Open, PO675- Cylinder 5 Glow plug circuit open. I was told by a diesel mechanic with the low voltage from the bad batteries and were the truck barley over headed it might be the FICM went bad so I checked the voltage coming out of the FICM and it still pushing out 48. What would make these codes come up all at once and make my truck shake when you start it and drive it?
Old Sep 14, 2014 | 03:26 PM
phillips91's Avatar
phillips91
Moved to 6.0 forum.
Old Sep 14, 2014 | 03:33 PM
npccpartsman's Avatar
npccpartsman
You can have 48V out of the FICM and still have a bad FICM.
Old Sep 14, 2014 | 03:40 PM
Is there any other ways to test the FICM to see if it is bad?
Old Sep 14, 2014 | 04:16 PM
AllaboutMPG's Avatar
AllaboutMPG
Did you check it cranking and running. It would help if you had a scan tool that will read the truck
Here's some good trouble shooting for the FICM without a scanner
Dr.Huxtable
Jul 27, 2020 03:33 AM
Ravenslair
Jul 5, 2019 10:15 AM
Sep 14, 2014 09:01 PM
npccpartsman
Jul 17, 2013 10:48 AM
qwertmonkey
Dec 24, 2011 01:18 PM
