Towing problems
Old Sep 15, 2014 | 11:03 AM
xr7gt390's Avatar
xr7gt390
The OPs issue is either a simple electrical fix that can be fixed by checking for voltage at various spots in the truck or his truck was flashed incorrectly. Since the trailer simulator worked at the dealer and the trailer works connected to another Ford, I would start with the connection to the trailer. His pin could be dirty, bent, pushed in or something preventing a good electrical connection.
Old Sep 15, 2014 | 11:27 AM
CDone's Avatar
CDone
All pins are clean and straight. Dealership here is positive that the truck was not flashed properly. Managed to get an appointment at a 3rd dealership this afternoon to get the computer re-flashed so hopefully we can get on with our vacation. Fingers crossed.
Old Sep 15, 2014 | 04:59 PM
xr7gt390's Avatar
xr7gt390
Hopefully you found a good dealership. Once the controller works it's nice. Good Luck.
Old Sep 15, 2014 | 06:30 PM
CDone's Avatar
CDone
Problem solved. Thanks guys. CPU was never flashed. Just hooked up the trailer and everything works great. Big thanks to Jacobsen Ford in Salmon Arm BC for getting me up and running.
Colin
Old Sep 16, 2014 | 08:45 AM
FordServiceCA's Avatar
FordServiceCA
Official Ford Rep
Colin
Glad to hear this was taken care of, Colin. I'm happy to document your dealer feedback. Please send me a private message with your full name and best daytime contact number and I'll get started on that right away! Additionally, I'll be here to answer any other questions you have moving forward. Have a great day!
Brittany
Old Sep 17, 2014 | 06:58 PM
hammer65's Avatar
hammer65
I had a 2012 XL, no hitch, or trailer package of any kind.
I installed the Ford Brake Controller and added the wiring harness with the seven pin plug.
Dealer flashed the controller, and his machine showed everything was fine.
Hooked to trailer and 'no trailer attached"
Well there was a wire from the plug connection on the left front fender, that had the controller wire going that far, but was not there, to go on to the new harness in the rear.
Dealer Tech added the wire, and everything went as designed.
No one knows if the wire was supposed to be there or not, from the factory. Just my .02
DGMFORD
Sep 30, 2020 08:59 PM
Eric Ahl
All Things Towing
25
May 28, 2017 07:06 PM
MYTRUCKNOWRATTLES
6.7L Power Stroke Diesel
53
Nov 27, 2013 08:50 AM
dixoncity
23
Aug 30, 2011 09:22 PM
DuallyMike
Nov 25, 2009 05:41 AM
