Lights, wiring...UGH!
Old Sep 14, 2014 | 10:13 AM
ADTMan's Avatar
ADTMan
Howdy Ya'll. It's sure been a while since I have been on here. I am at a point that I need help with my truck, and once again, I am turning to you guys!
93 F250 5spd 4x4 Ex Cab - power everything.
Issues - Headlights, no running lights and no brake lights. Dome light comes on. Here is what I have done so far:
Replaced multi-function switch
Replaced headlight switch
Wired brake lights direct, now they obviously work.
I have checked fuses and found none bad. I am lost and so frustrated with this truck.
Is there someplace that sells complete wiring harnesses for our trucks? Engine, frame and cab?
HEP ME HEP ME HEP ME
Thanks
Old Sep 14, 2014 | 10:15 AM
David7.3's Avatar
David7.3
Painless Wiring has complete harness's or just the one's your looking for!
Old Sep 14, 2014 | 10:44 AM
ADTMan's Avatar
ADTMan
Ok, I am so googling them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 14, 2014 | 11:04 AM
tecgod13's Avatar
tecgod13
Have you checked the ground connections?
Old Sep 14, 2014 | 12:44 PM
bashby's Avatar
bashby
You can get a new plug for the headlight switch. Thay commonly overheat and fail. You're most likely going to have more time and money in replacing the harness than diagnosing and fixing your truck.
Old Sep 14, 2014 | 04:41 PM
ADTMan's Avatar
ADTMan
Well if I could diagnose and fix I would, hence just swapping parts is easier...maybe. LOL I am just frustrated. Even before this the truck keeps eating batteries. I can't keep them charged unless I drive it every day. I do not know what is draining them. I am thinking that if I find the problem with the lights I might find that problem is causing multiple problems.
Old Sep 14, 2014 | 04:53 PM
bashby's Avatar
bashby
If you wanta keep throwi g parts at it Id try.the.headlight switch connector next. Should be available local and very well couldfix the parking lights. I doubt it will effect brake.lights
Old Sep 14, 2014 | 04:54 PM
bashby's Avatar
bashby
All the parking lights front and rear are inop, right?
Old Sep 14, 2014 | 05:19 PM
ADTMan's Avatar
ADTMan
Correct all of them are out except for the headlights themselves.
Old Sep 14, 2014 | 05:25 PM
bashby's Avatar
bashby
Did you visually check fuses or probe the back with a testlight? A bad fuse can look good, especially the lower amp ones.
Test light method is if you have power on one side you should have it on the other of thw.fuse
patrickmcl
Nov 18, 2012 03:11 PM
3360stepp
Oct 5, 2011 09:18 AM
TonysIrishPrincess
Jan 28, 2010 08:32 PM
walnut777
Aug 15, 2008 11:10 AM
Trail_Rider
Feb 4, 2001 08:40 PM
