What would you do ?
loved my 2012 f250 with 20" michelins and only reason I traded when it got to 45k or so is to up the gvwr and a new f350 for the new rv.... Love my truck, BUT, the 350's 20" michelins are done @ 23k !!! out of round or band broken or something that showed up on the last rotation... they tried road force balance,but no better...
dealer says Michelin will give me a new set and prorate them @ 65%,
so I have to come up with $520 or so...
Told him that wasn't acceptable in that I had all my maintenance done with you, all at the right intervals, including rotations and you can tell me a reason for the issue...
I told him:
at this rate, I'm not sure I want Michelins if I am going to get 20K out of them and go talk to whomever and come back with a better offer...
I think these are the tires --> http://www.tirerack.com/tires/tires....lar=Crew%20Cab
What's your opinion... not worth talking to my attorney, but not real happy over it...
You have been a great customer for that dealer, they should take care of you if Ford/Michelin won't. I have been happy with my 18s and will have them also on my new F350. I will stick with them over the 20s due to price and how I use them in the Mtns and woods.
You could trade up to a new 2015, get the extra power, and the engine brake.... LOL...
I would continue to work up the chain till you get an acceptable solution.
Pat
My only thought is Michelin does other brands (BFG comes to mind), see if they'll open up more choices to you that way.
It sounds like your guy is working the Michelin angle on your tires. If you want full replacement, escalate it with Ford. It will really help your case if you can prove a safety issue rather than just tread wear. You are still covered under the 3/36 warranty so it should be doable.
I have never felt that 20" low pro tires have a place on a truck that is going to be used for actual truck duties of use of carrying weight or towing.
To me there just isn't enough sidewall there to flex and compensate for a heavy load on the roads of todays current infrastructure (IE: our roads suck).
They are pretty to look at, they give a truck nice photographic appeal, but to me those benefits are not worth the cost of the tire over the 16" or 17" tire size.
For me, give me a properly rated tire, with a tread pattern designed for what use it will see. Then wrap some sidewall to it and lets hit the road.
As for the offer the dealership has put on the table, I would have to say that they are being fair. Of course I'm not the one writing the check out for the $520+ difference.
The cost of tires has skyrocketed in general and this is especially true for the 20" tires. Back in 06 everybody thought I was crazy to have the 20" wheels and all they could talk about was how expensive the tires must be. I put 4 new tires on that truck in early 09 for less than $600! Today at least in the OEM Michelin A/T2, the cost differential between the 18" and the 20" tire is less than 10%. You are looking at $300 plus per tire for these trucks regardless of size unless you go with an inferior tire.
I can understand that the tire may be rated to carry a few pounds more per tire. My issue is that given some of the pot holes I have driven over due to the highway road conditions I would rather have the side wall height that allows for some added suspension/compression than have concerns of hitting one of these monster bottomless potholes causing a blowout and or causing rim damage in the process.
One thing I knew, but due to old age and cranial gas did miss and forgot to take into account is the single rear wheel axle on the OPs truck.
See, I'm a dually guy and keep forgetting that many owners use a SRW truck to haul large 5th wheel trailers.
I usually tow 10k or less and I run tire psi at 72 most of the time and have had good luck getting over 50k from a set of tires. It pays to rotate often as the rears will lose tread depth quickly and the front round over the edges fairly quickly.
I know you know all of this, but I post it just as my opinion.
If the tires don't make you comfy, just bite the bullet and get some Cooper A/T 3 tires. They're expensive but I've got over 60k on my current set and I think they'll last until November when I get the new truck.
Standing on principle with your tire warranty will only get you so far when your adversary doesn't agree with you. It's hard to get people to swallow their pride and do the right thing when they don't have a specific statement by their superiors to back them if there's an issue.
If you can't beat them, play the game by their own rules, just choose and pick the rules you want to use.
Yeah, I know it's probably something odd in that one tire has a 'slope' across the tire of 2 or 3/32 according to the dealer...
269 per @ discount or tirerack about $1270 out the door total *.35 = $445 out of pocket... so there's some room there...
I did look and they have a 6yr/ 60k mile warranty:
Treadlife Warranty: 6 Years / 60,000 Miles
Uniformity Warranty: 1 Year / first 2/32" of wear
Workmanship & Materials Warranty: 6 Years / Free replacement first year, 2/32" or 25% of wear, then prorated until 2/32" remaining depth
Manufacturer's Road Hazard Warranty: None
Manufacturer Special Warranty: 30-day satisfaction, 3-yr flat changing
will 'discuss' further options with them Monday... and keep the Michelin $70 rebate before 9-21 in my back pocket
Here is my rub - I wouldn't want to put the SAME tire back on and expect anything different than getting 20k miles out of them. If they will give you the pro-ration back and let you pick a different tire, that is what I would do preferably. However, you will pay less to put a new set of tires back on the truck on the same type/brand than you would any other... So it is a tough choice.
Sounds like you are working this out in your head though. Unfortunately my dry rotted/cracked tires were only covered for 3 years on the factory tires and were therefore, not warranted at all...
the local dealer decided to split the difference so I told them to do it even though I still believe it was nothing I did or didn't do...
just will be more proactive on the rotations and now that I got rid of the fake rancho's shown below, hoping that will help...
will keep you posted on the future results...
