Lotsa codes
Old Sep 11, 2014 | 10:53 PM
scott the jensen's Avatar
scott the jensen
Lotsa codes
Hello everyone I'm getting an o2 sensor code ,o2 htr code, evap code, catalyst code, comp code, fuel code, and finally a po352 which is a coil pack, I took the truck in to my mechanic and he has replaced two coil packs drivers side catalytic converter and some sort of timing valve on top of motor on passenger side. It's a 2005 F250 fx4and these codes popped up after the work he did and I have been taking my vehicles to him for twenty years any ideas?
Old Sep 12, 2014 | 04:09 PM
galaxie641's Avatar
galaxie641
A person would need the actual code numbers. For example an "O2 code" could be half a dozen different numbers and they all mean something different and relate to each other in their own way.
Old Sep 21, 2014 | 08:08 AM
nv2713f250's Avatar
nv2713f250
Check the connection of the wires to each coil and make sure the plug actually clicks into place. A loose connection to a coil will cause RF frequency making the pcm confused with what it wrong.
Old Sep 21, 2014 | 02:11 PM
projectSHO89's Avatar
projectSHO89
Blown fuse.
Psygnosis
Jun 7, 2013 10:53 AM
itsafordguy20
Jul 26, 2008 09:49 AM
greenterror
Jan 21, 2008 02:01 PM
yuenglag
1997 - 2003 F150
Oct 18, 2005 10:23 AM
mike0454
1978 - 1996 Big Bronco
Sep 8, 2002 10:46 AM
