Sponsored by: Real Truck
5.4 help lease
Old Sep 10, 2014 | 06:25 AM
ruschejj's Avatar
ruschejj
5.4 help lease
I posted this topic in the expedition forum but I'm also asking y'all to give me advice too.
Hi all, our 2008 expedition has 105,000 miles on it, been completely reliable and pleasant to drive. Recently it has become very sluggish.
Down on power
Starts and runs normally
No other symptoms, temps all normal
Running same gas as always
Consistent maintenance, fresh air filter, frequent oil changes
It's just sluggish, noticeable when going 35 and wanting to accelerate to 55, takes a long time, high rpms just don't have the oooomph it used to.
So, what ages and makes this motor lose power? I need to bring it back to the way it should be but without any codes thrown or any noises/smells/symptoms it's hard for me to know what to do.
Please give me your ideas/experiences.
__________________
2011 F250 6.7 4X4 Lariat Ultimate FX4 3.55 ELock
Polk Audio component speakers, AFE Stage 7 intake
Sho Me Strobes, Shocker XL Horns, BakFlipG2
2 Kicker 10" subs, Rockford Fosgate amp
Ride-Rite air bags, VIAIR #10007 onboard air, AFE DPF back exhaust, power slot rotors/EBC pads, Nitto Trail Grapplers M/T 295/55 R20! Transfer-Flow 50 gal tank
Old Sep 10, 2014 | 06:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
These engines will last an easy 500,000 miles. Some have been documented to last over 1.2 million miles.
Something is wrong with your engine. Start with the basics. Was the engine tuned up at 100,000 miles?
What is your fuel pressure? When was the fuel filter last changed?
Old Sep 10, 2014 | 06:30 AM
ruschejj's Avatar
ruschejj
Ok, will check the fuel system. Admittedly, I don't know where the fuel filter is. I will find out though.
Would new spark plugs help? I didn't put new ones on yet. Thanks for the ideas.
Old Sep 10, 2014 | 06:36 AM
redford's Avatar
redford
Yes. New spark plugs would help. Your spark plugs should have been changed at 90,000 miles, along with your fuel filter.
Continued driving like this could result in you burning up your catalytic converters.
Old Sep 10, 2014 | 06:37 AM
redford's Avatar
redford
You can pull up your PM schedule here.
Maintenance Schedules | fleet.ford.com
Old Sep 10, 2014 | 06:39 AM
ruschejj's Avatar
ruschejj
Thanks Stuart. I will work on it this evening.
Old Sep 10, 2014 | 07:00 AM
Tom's Avatar
Tom
All good suggestions, but I'm pretty confident many of these things would cause trouble codes that would set the CEL. For example a plugged fuel filter would cause a lean condition. The spark plugs definitely need to be changed if they're original, but I don't think they can cause lack of power without misfiring.
If there are no other symptoms it almost seems like you have an obstructed intake or exhaust system. Just a WAG, but your converters may be on the way out. Hope not, they're not cheap!
Old Sep 10, 2014 | 08:54 AM
speakerfritz's Avatar
speakerfritz
a. carbon build up
b. spark plug status
c. how's the fuel filter
d. when does your area switch to modified gas ....is this what you are sensing?
Old Sep 10, 2014 | 08:58 AM
gasman6674's Avatar
gasman6674
I vote for a strangled cat. Had two of them on an escape and it would not get out of its own way.
Old Sep 10, 2014 | 12:09 PM
RigTrash601's Avatar
RigTrash601
X2 on the cats......
A full "tune up" wouldn't hurt either. How is your MPG's? Still getting about the same as before it started acting sluggish?
Old Sep 10, 2014 | 07:53 PM
ruschejj's Avatar
ruschejj
Thanks for all the input gents.
Mpg is a solid 16 around town all the time, but my wife drives it and it may as well be my grandmother with the way she babies it. She's a careful moderate driver with our kids in the seats.
I went ahead and got new plugs, just got into it tonight to see what I'm in for. Turns out I'm kind of in trouble. The guy at the parts counter sold me new boots for the new plugs, and now that I took one apart I get it, seems like a good idea.
Anyway, it's running on 7 cylinders right now because I can't get the spring to seat on the top of the plug. How do I seat that spring properly? I think I will figure it out in the morning but dang, it's not easy is it?
Old Sep 10, 2014 | 08:09 PM
senix's Avatar
senix
I'd check that exhaust for a restriction myself. Almost sounds like it is plugged up.
Old Sep 10, 2014 | 08:47 PM
phillips91's Avatar
phillips91
X2. You can take an O2 sensor out and see if it runs any better. If the cat is clogged up this will allow the exhaust to escape before getting to the cats and choking the engine off.
ruschejj
17
Nov 26, 2015 08:13 AM
buddyp
Jan 25, 2011 10:11 PM
jmm137
2004 - 2008 F150
Dec 22, 2010 08:14 PM
hugger94
1997 - 2003 F150
Mar 10, 2008 10:05 AM
Soccer85
1983 - 2012 Ranger & B-Series
Sep 16, 2006 05:14 PM
