Check the brake rotors. On my truck the inside of the driver side rotor was eaten up and had deep grooves. Otherwise you will have to just take the wheels off and see which one has play. Normally if one goes the other isn't far behind so if you do find a bad one replace both and save yourself the aggravation a couple months later.
What makes this so frustrating is that I just completely rebuilt the entire front end about 6500 miles ago!!
The problem I'm having now, is the reason i rebuilt my front end.
You could pull the ABS sensor out and see if you see any thing that would help you decide which side to start with.
Is it still wandering left and right or just bouncing and growling. Maybe you could tighten the gearbox to clear up left and right issue.
The left/right wandering is probably due to the slop in my steering box. (Almost saved enough for a Redhhead Box) Still bouncing and growling also. What should I inspect by pulling the ABS sensor?
If you have a growling noise and intermit abs light you may find some metal shavings or other indication if one is bad. Not a guarantee but it's one bolt to pull the sensor and look down into the hub. You may not find anything but it's easy enough.
Have you jacked it, taken wheel off(to get weight off hub) and tried to move from the u-joint side of the hub looking for excessive play?
You are sure your hubs are unlocked? Front U joints/axles should not be turning unless in 4 wd. Had the front end growl growl 8-9 years ago and the dealership wanted to put new hubs on. Thanks to the boys at the Dieselstop, I got my hubs unlocked and am still on the original hubs to this day.
I pretty sure they are unlocked. They are brand new Warn premiums.
fairly easy to check. see if the u-joint and axle will turn by hand(both sides). if yes the hub is not locked. if it won't turn hub may be locked or something else could be hung
I am going to tear into it later this afternoon. I'll make sure to check that out, and i'll report back with what I find. Hopefully I find something.
The sound you are describing when turning the wheel sounds very similar to what mine used to do. It was resolved with a new wheel bearing hub assembly being installed.
Shimmy from my experience is caused by bad tie rod ends or a bad idler arm or pitman arm.
If you've replaced all of the above, then I am stumped.
I have done everything but the pitman arm, sway bar, steering box, and front drive shaft. Believe me, I'm stumped too!
I got under it this afternoon and looked for metal shavings and moved the ujoints to make sure the hubs weren't locked, and they were smooth as butter. Didn't find anything else out of the ordinary. The new ujoints from the stub axle to the axle are spicer, and they have grease zerks on them. Would that be a problem? Guess ill jack it up tomorrow and look a little deeper.
Just checking back in here. I had the chance to jack it up and grab the wheel at 3 o'clock and give it a shake. The whole center link moves just enough to make a clunk. Had a buddy come over and move the wheel like i did, while I got under it and tried to pinpoint where the play is, and I believe it's in the pitman arm. Also, I can move the passenger side ujoint at the stub, and it moves enough to clunk in the hub. I'm going to assume that this is the side I'm getting the random ABS light and howling/grinding sound from on slight left curves. Also, I looked at my fan, and it's got some pretty sizeable chunks missing on about 4 blades. Could that cause a motor vibration or front end bounce feeling? Still need to know what is grinding on the drivers side when I make a sharp enough right turn. It is now pulling to the right.
I'm really starting to think that I didn't install the knuckle seal and dust seal properly during the rebuild, and my axles are wobbling in the housing.
I doubt you'd get it back together if you didn't assemble it correctly unless you didn't install all of the thrust washers,(3 pieces). Then you would have play in the axel shaft.
You'd better pull the other hub bearing assembly off and check it too and replace the pitman arm.
Keep us posted.
If you fan blade has chunks out of it the my guess is that the fan clutch is toast thus causing your fan to wobble.
I would be checking the wheel hubs and seals to make sure they're installed correctly. Missing pieces in the fan is not a good thing and should be replaced ASAP.
I am revisiting this again, and have the right front wheel off. I can move the area near the stub axle ujoint that goes into the small dust seal in the front end. (Does that make sense?) It looks like the whole seal moves a little bit in the housing when I push on the ujoints.. When I installed this during the rebuild, I already had it on the axle when I slid it into the housing. Was I supposed to seat it in the housing first, THEN slide the axle through? Of course, with the larger knuckle seal already installed on the axle.
Yeah you should have seated the dust seal into the axel before installing the axel itself. However, compare how it is seated to the dust seal on the other side. A little movement as you described is ok.
