OK so... I have a ford excursion 2003 with a 6.0 a month ago I blew head gasket because of that damn EGR valve getting stuck so I took apart the motor new head gaskets complete kit oil cooler intake turbo gaskets finally got to assemble it all the other day since I had broken ribs otherwise I prolly would have been asking this earlier. The truck starts pretty much right away I drove around the block a few times has no power though when I mash the gas to the floor. I plugged in my scanner tool and im getting all these codes now can someone help me out im losing my mind :
from what I can tell nothing looks burnt and all the connectors are seated perfectly no wires rubbing or chaffing. as for the egr valve ill have to find one used since I have it blocked off I guess I can just plug it in and leave it resting on the motor?? because as I said I did the egr delete with block off
one more question I checked the harness had to fix a few wires they snagged but can I drive the truck without the egr plugged in im waiting for one to be delivered tomorrow cant believe 4 junkyards by me didn't have one I had to pay 190 for a new one ..
