1991 E150 ABS Hydraulic Unit
Old Sep 9, 2014 | 02:55 AM
freevan's Avatar
freevan
Hi All, Does anyone know where the ABS hydraulic unit is located in the 1991 E150 Econoline 2wd with an E4OD transmission. I have had a check light for a long time and just replaced the sensor in the rear differential, but the light is still on. The old sensor did not have hardly any metal on it. The brakes work fine with the light on. The real problem I am having is with 2-3 upshift, but now I have the pan down and found the filter lying in the pan. I am going to retorque all the bolts and add a filter clip, change the fluid which is not burnt.
freevan
Sep 13, 2014 02:12 PM
gasman6674
Aug 9, 2010 02:50 PM
Norfra
1997 - 2003 F150
Apr 4, 2008 06:30 AM
busdriver47
Apr 7, 2006 03:05 PM
ekelly
Oct 3, 2003 04:46 PM
